Fi Car Audio - модельный ряд и цены 2012/2013
Skillz
Как многие наверное догадались, помимо Sundown Audio, XS Power и Ascendant Audio мы так же теперь представляем Fi Car Audio :good:
Вот текущий модельный ряд и цены:
IB3 - 550w RMS @20hz - (это саб для бесконечного экрана - Free-Air - Infinite Baffle )
12" - 14900р - параметры Оффтоп
IB3 Series: 12”, 15”, and 18”
Single 2 and Single 4 Ohm
Cast basket
Wrap around gasket
Kraft pulp fiber reinforced cone
Single layer wide foam surround
Push terminals
Extra heavy lead wire
FEA optimized motor
3” diameter 2 or 4 layer coil
Large single magnet
Single progressive spider
IB312
SINGLE 2 | SINGLE 4
Fs: 23.6 Hz | 23.6 Hz
Re: 1.5 Ohms/coil | 2.8 Ohms/coil
Qms: 4.06 | 4.00
Qes: .67 | .64
Qts: .57 | .55
Mms: 217g | 214g
Sd: 480cm^2 | 480cm^2
Vas: 83.2 l | 83.4 l
Spl: 83.2dB 1W/1m | 83.4dB 1W/1m
Bl: 8.43 N/A | 11.8 N/A
Xmax: 30mm
Rms: 550W @ 20Hz
Sealed box: Infinite Baffle Only
Ported box: N/A
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 6.500”
Displacement: 0.14cuft
15" - 15500р - параметры Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
Large single magnet
IB315
SINGLE 2 | SINGLE 4
Fs: 22.7 Hz | 22.8 Hz
Qms: 4.30 | 4.28
Qes: .74 | .70
Qts: .63 | .61
Mms: 247g | 244g
Sd: 810cm^2 | 810cm^2
Vas: 183.3 l | 183.3 l
Spl: 86.4dB 1W/1m | 86.7dB 1W/1m
Xmax: 30mm
Rms: 550W @ 20Hz
Ported box: N/A
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.000”
Displacement: 0.17cuft
18" - 17500р - параметры Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
Large single magnet
IB318
SINGLE 2 | SINGLE 4
Fs: 22.3 Hz | 22.5 Hz
Qms: 3.33 | 3.41
Qes: ..81 | .77
Qts: .65 | .62
Mms: 272g | 270g
Sd: 1210cm^2 | 1210cm^2
Vas: 381 l | 381 l
Spl: 89.1dB 1W/1m | 89.4dB 1W/1m
Xmax: 30mm
Rms: 550W @ 20Hz
Ported box: N/A
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 9.500”
Displacement: 0.22cuft
SSD - 1000w RMS - Отличный универсальный саб для повседневных систем. Трехдюймовая катушка и отличное охлаждение. Отлично себя чувствует как в ЗЯ, так в ФИ.
10" - 15000р - параметры - Оффтоп
SSD Series: 10”, 12”, 15”, and 18”
Dual 1 and Dual 2 Ohm
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
3” diameter 4 layer coil
Single high grade magnet
Triple progressive spiders
Optional Heli-cool system
SSD10
DUAL 1 | DUAL 2
Fs: 31.0 Hz | 0 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 7.07 | 7.07
Qes: .35 | .35
Qts: .33 | .33
Mms: 223g | 223g
Cms: 0.12mm/N | 0.12mm/N
Sd: 310cm^2 | 310cm^2
Vas: 15.9 l | 15.9 l
Spl: 83.2dB 1W/1m | 83.2dB 1W/1m
Bl: 13.1 N/A | 18.7 N/A
Xmax: 20mm
Rms: 1000W
Sealed box: H-Qts .2-.4 cuft
Ported box: .6-1.2 cuft @ 33Hz
Sub OD: 11.000”
Cut ID: 9.250”
Mounting depth: 6.000”
Displacement: 0.12cuft
12" - 16000р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
SSD12
DUAL 1 | DUAL 2
Fs: 30.1 Hz | 30.1 Hz
Qms: 7.65 | 7.65
Qes: .37 | .37
Qts: .36 | .36
Mms: 248g | 248g
Cms: 0.11mm/N | 0.11mm/N
Vas: 36.5 l | 36.5 l
Spl: 86.1dB 1W/1m | 86.1dB 1W/1m
Xmax: 20mm
Rms: 1000W
Sealed box: .7-1.2 cuft
Ported box: 1.8-2.5 cuft @ 33Hz
Sub OD: 12.500”
Cut ID: 11.125”
15" - 17500р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
SSD15
DUAL 1 | DUAL 2
Fs: 29.6 Hz | 29.6 Hz
Qms: 8.73 | 8.73
Qes: .43 | .43
Qts: .41 | .41
Mms: 288g | 288g
Cms: 0.10mm/N | 0.10mm/N
Vas: 93.0 l | 93.0 l
Spl: 89.3dB 1W/1m | 89.3dB 1W/1m
Xmax: 20mm
Rms: 1000W
Sealed box: 1.5-2.5 cuft
Ported box: 3-4 cuft @ 33Hz
Sub OD: 15.625”
Cut ID: 14.125”
18" - 19500р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
SSD18
DUAL 1 | DUAL 2
Fs: 27.6 Hz | 27.6 Hz
Qms: 9.56 | 9.56
Qes: .47 | .47
Qts: .45 | .45
Mms:338g | 338g
Cms: 0.098mm/N | 0.098mm/N
Vas: 201.4 l | 201.4 l
Spl: 91.4dB 1W/1m | 91.4dB 1W/1m
Xmax: 20mm
Rms: 1000W
Sealed box: 3.5-5 cuft
Ported box: 6-10 cuft @ 33Hz
Sub OD: 18.500”
Cut ID: 16.750”
Q - 1500w RMS - - референсная линия для качественного и мощного баса. мощный мотор и большой линейный ход
10" - 19900р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
3" diameter 4 layer coil
Quad progressive spiders
High or low Qts motors
And many other custom options
Q10
DUAL 1 | DUAL 2
Fs: 34.1 Hz | 34.0 Hz
Re: 0.70 Ohms/coil | 1.4 Ohms/coil
Qms: 7.31 | 7.38
Qes: .37 | .37
Qts: .36 | .36
Mms: 230g | 2235g
Cms: .88mm/N | .88mm/N
Vas: 11.8 l | 11.8 l
Spl: 83.3dB 1W/1m | 83.2dB 1W/1m
Bl: 13.9 N/A | 19.6 N/A
Xmax: 28mm
Rms: 1500W
Sealed box: .2-.5 cuft HQTS
Ported box: .5-1.2 cuft @ 28-33Hz
Sub OD: 11.000”
Cut ID: 9.250”
12" - 21000р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
Q12
DUAL 1 | DUAL 2
Fs: 34.2 Hz | 33.9 Hz
Qms: 7.63 | 7.69
Qes: .39 | .39
Qts: .37 | .37
Mms: 249g | 253g
Cms: 0.87mm/N | 0.87mm/N
Sd: 481cm^2 | 481cm^2
Vas: 28.3 l | 28.3 l
Spl: 86.5dB 1W/1m | 86.3dB 1W/1m
Bl: 13.9 N/A | 19.65 N/A
Xmax: 28mm
Rms: 1500W
Sealed box: .8-1.5 High QTScuft
Ported box: 1.8-2.5 cuft @ 28-33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 7.000”
Displacement: 0.16cuft
15" - 22500р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
Q15
DUAL 1 | DUAL 2
Fs: 32.4 Hz | 32.1 Hz
Qms: 8.52 | 8.61
Qes: .43 | .44
Qts: .41 | .42
Mms: 293g | 299g
Cms: 0.82mm/N | 0.82mm/N
Vas: 75.6 l | 75.6 l
Spl: 89.6dB 1W/1m | 89.4dB 1W/1m
Xmax: 28mm
Rms: 1500W
Sealed box: 2-2.6 cuft
Ported box: 2.8-4 cuft @ 28-33Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.500”
Displacement: 0.19cuft
18" - 24000р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
Q18
DUAL 1 | DUAL 2
Qms: 9.31 | 9.37
Qes: .48 | .48
Qts: .46 | .46
Mms: 341g | 347g
Cms: 0.73mm/N | 0.73mm/N
Vas: 149.7 l | 149.7 l
Spl: 92.0dB 1W/1m | 91.9dB 1W/1m
Xmax: 28mm
Rms: 1500W
Sealed box: 4-8 cuft
Ported box: 6-10 cuft @ 28Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 10.000”
Displacement: 0.24cuft
BL - 1500w RMS - это линейка - тонкая грань которая разделяет повседневные сабы и СПЛ-монстры.
10" - 23500р - параметры - Оффтоп
BL Series: 10”, 12”, 15”, and 18”
Dual 1 and Dual 2 Ohm (custom options available)
Cast basket
Wrap around gasket
Push terminals
16 integrated leads
FEA optimized motor
High Flux density design
3” diameter 4 layer coil (Flatwind option)
Double stack magnets
Five progressive spiders
Optional Heli-cool systerm
Machined in house at Fi
BL10
DUAL 1 | DUAL 2
Fs: 37.1 Hz | 37.1 Hz
Qms: 4.62 | 4.62
Qes: .23 | .23
Qts: .22 | .22
Mms: 191g | 191g
Cms: 0.96mm/N | 0.96mm/N
Vas: 13.0 l | 13.0 l
Spl: 86.2dB 1W/1m | 86.2dB 1W/1m
Bl: 16.6 N/A | 22.7 N/A
Xmax: 18mm | 18mm
Rms: 1500W * | 1500W *
Sealed box: N/A cuft | N/A cuft
Ported box: .7-1.5cuft | .7-1.5cuft
Sub OD: 11.000” | 11.000”
Cut ID: 9.250” | 9.250”
Mounting depth: 6.250” | 6.250”
Displacement: 0.16cuft | 0.16cuft
12" - 24500р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
16 integrated leads
FEA optimized motor
BL12
DUAL 1 | DUAL 2
Fs: 35.2 Hz | 39.8 Hz
Qms: 4.68 | 4.72
Qes: .25 | .25
Qts: .24 | .24
Mms: 212g | 212g
Vas: 31.2 l | 31.2 l
Spl: 89.1dB 1W/1m | 89.1dB 1W/1m
Xmax: 18mm | 18mm
Ported box: 1.5-2.5cuft | 1.5-2.5cuft
Sub OD: 12.500” | 12.500”
Cut ID: 11.125” | 11.125”
Mounting depth: 6.750” | 6.750”
Displacement: 0.18cuft | 0.18cuft
15" - 26500р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
16 integrated leads
FEA optimized motor
BL15
DUAL 1 | DUAL 2
Fs: 33.6 Hz | 33.6 Hz
Qms: 5.21 | 5.21
Qes: .28 | .28
Qts: .27 | .27
Mms: 261g | 261g
Cms: 0.86mm/N | 0.86mm/N
Vas: 78.9 l | 78.9 l
Spl: 91.8dB 1W/1m | 91.8dB 1W/1m
Xmax: 18mm | 18mm
Ported box: 3-5cuft | 3-5cuft
Sub OD: 15.625” | 15.625”
Cut ID: 14.125” | 14.125”
Mounting depth: 8.250” * | 8.250” *
Displacement: 0.21cuft * | 0.21cuft
18" - 28000р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
16 integrated leads
FEA optimized motor
BL18
DUAL 1 | DUAL 2
Fs: 33.2 Hz | 33.2 Hz
Qms: 5.82 | 5.82
Qes: .32 | .32
Qts: .30 | .30
Mms: 302g | 302g
Cms: 0.88mm/N | 0.88mm/N
Vas: 181.0 l | 181.0 l
Spl: 94.1dB 1W/1m | 94.1dB 1W/1m
Xmax: 18mm | 18mm
Ported box: 5-8cuft | 5-8cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth: 9.750” * | 9.750” *
Displacement: 0.26cuft * | 0.26cuft *
Для просмотра параметров интересующей модели, жмем OFFTOPIC возле соответствующего пункта.
Изменено пользователем Skillz
BTL N3 - 3000w RMS - создан с одной цель - быть первым в SPL. Легенда в неодиме и максимальной эффективности :good:
12" - 48000р - параметры - Оффтоп
BTL Series: 12”, 15”, and 18”
Cast basket
Wrap around gasket
Push terminals
16 integrated leads
FEA optimized motor
3” diameter 8 layer coil (High Xmax coil option)
Triple Neodymium high flux magnets
5-7 progressive spiders packs
Tri-flow integrated heatsink
N312
DUAL 1 | DUAL 2
Fs: 56.3 Hz | 55.3 Hz
Qms: 7.45 | 7.69
Qes: .26 | .25
Qts: .25 | .24
Mms: 214g | 222g
Vas: 12.1 l | 12.1 l
Spl: 91.1dB 1W/1m | 90.8dB 1W/1m
Bl: 20.2 N/A | 28.8 N/A
Xmax: 28mm | 28mm
Rms: 3000W | 3000W
Mounting depth: 7.250” | 7.250”
15" - 49000р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
16 integrated leads
FEA optimized motor
N315
DUAL 1 | DUAL 2
Fs: 54.5 Hz | 54.4 Hz
Qms: 9.19 | 9.28
Qes: .32 | .32
Qts: .31 | .31
Mms: 274g | 280g
Vas: 28.95 l | 28.95 l
Spl: 93.4dB 1W/1m | 93.3dB 1W/1m
Xmax: 28mm | 28mm
Rms: 3000W | 3000W
Ported box: 2.5-5cuft | 2.5-5cuft
Mounting depth: 8.750” | 8.750”
Displacement: 0.21cuft | 0.21cuft
18" - 52000р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
16 integrated leads
FEA optimized motor
N318
DUAL 1 | DUAL 2
Fs: 51.1 Hz | 50.4 Hz
Qms: 10.1 | 10.26
Qes: .36 | .35
Qts: .35 | .34
Mms: 320g | 329g
Vas: 62.1 l | 62.1 l
Spl: 95.3dB 1W/1m | 95.4dB 1W/1m
Xmax: 28mm | 28mm
Rms: 3000W | 3000W
Ported box: 4-10cuft | 4-10cuft
Mounting depth: 10.250” | 10.250”
Displacement: 0.26cuft | 0.26cuft
SP4 - 2500w RMS - - Монстр с 4х-дюймовой катушкой. Огромный ход и низкая резонансная частота. Идеальный динамик для громкого повседнева
12" - ????
15" - 37500р - параметры - Оффтоп
SP4 Series: Currently in 15” and 18”
Extra heavy aluminum basket
Wrap around gasket
Push terminals
144 tinsel count leads
FEA optimized motor
4” diameter 4 layer coil (Flatwind standard)
Five progressive 10" spiders
SP415
DUAL 1 | DUAL 2
Fs: 27.6 Hz | 27.9 Hz
Re: 0.65 Ohms/coil | 1.27 Ohms/coil
Qms: 6.56 | 6.45
Qes: .52 | .52
Qts: .48 | .48
Mms: 434g | 424g
Cms: 0.77mm/N | 0.77mm/N
Vas: 70.4 l | 70.4 l
Spl: 86.4dB 1W/1m | 86.5dB 1W/1m
Bl: 13.7 N/A | 19.1 N/A
Xmax: 33mm | 33mm
Rms: 2500W | 2500W
Sealed box: 2-3.5cuft | 2-3.5 cuft
Mounting depth: 11.250” | 11.250”
18" - 39000р - параметры - Оффтоп
Wrap around gasket
Push terminals
FEA optimized motor
SP418
DUAL 1 | DUAL 2
Fs: 24.7 Hz | 24.9 Hz
Qms: 7.45 | 7.38
Qes: .60 | .59
Qts: .55 | .55
Mms: 555g | 544g
Cms: 0.74mm/N | 0.74mm/N
Vas: 153.7 l | 153.7 l
Spl: 87.8dB 1W/1m | 87.9dB 1W/1m
Xmax: 33mm | 33mm
Rms: 2500W | 2500W
Sealed box: 4-6 cuft | 4-6 cuft
Ported box: 6-8cuft | 6-8cuft
Mounting depth:11.750” | 11.750”
Сп4 параметр рмс был 2500ватт а стал 3000ватт.
Так то насос в поряде, катуха аж пугает. За машину теперь буду переживать.
Изменено пользователем Денис 762
:good:
Денис 762, а ещё какие-нибудь параметры известны,кроме рмс?) Вот по цене например,восемнаха за бугром со всеми доп.опциями(cooling,space spider) будет стоить ,а в России?))
Денис 762, а ещё какие-нибудь параметры известны,кроме рмс?) Вот по цене например,восемнаха за бугром со всеми доп.опциями(cooling,space spider) будет стоить$,а в России?))
SP415
DUAL 1 | DUAL 2
Qms: 6.56 | 6.45
Qes: .52 | .52
Qts: .48 | .48
Mms: 434g | 424g
Xmax: 33mm | 33mm
Rms: 3000W | 3000W
Sealed box: 2-3.5cuft | 2-3.5 cuft Ported box: 3-5cuft | 3-5cuft Sub OD: 15.625” | 15.625” Cut ID: 14.125” | 14.125” Mounting depth: 11.250” | 11.250” Displacement: 0.21cuft | 0.21cuft
:good:
Что по цене известно на обновлённый SP4 ?))
Цена не изменилась :good:
а что за обновленный SP4 ?
DDM4A*(2)DD3510*DDc3b*(4)DDАW6.5
FI SP418*Hawker 400
