CADENCE сабвуферы
Илья 37
Daytona Series (Professional Competition)
DCX34-W
http://www.cadencesound.com/products/DCX34W.html
34",
магнит - 14кг,
вес динамика - 103кг,
звуковая катушка - 5",
2+2Ом,
12Hz-600Hz,
MAX мощность - 10 000 W,
RMS - 5 000 W,
SPL 91dB +/- 3dB
ZRS Series
ZRS-ZB121
http://www.cadencesound.com/products/ZB121
12" корпусной сабвуфер,
RMS 1000 Вт,
MAX 2000 Вт.
UD Series (ULTRADRIVE)
CVL8-500-4
http://www.cadencestore.com/ProductCart/pc/viewPrd.asp?idcategory=179&idproduct=649#details
200mm
500w RMS/1000w max
92дБ
4 ом
Pro Series
PRO 10X4
http://www.cadencesound.com/products/PRO10X4.html
СУПЕР дополнение к мидбасам!
Сабвуферный динамик 10",
4Ом,
RMS 400Вт,
MAX 800Вт,
55Гц-4кГц,
95дБ
PRO12X4
http://www.cadencesound.com/products/PRO12X4.html
Сабвуферный динамик 12",
4Ом,
RMS 400Вт,
MAX 800Вт,
50Гц-4кГц,
95дБ
PRO15X4
http://www.cadencesound.com/products/PRO15X4.html
Сабвуферный динамик 15",
4Ом,
RMS 400Вт,
MAX 800Вт,
40Гц-3кГц,
97дБ
НОВИНКИ ЭТОГО СЕЗОНА!!!
S0W10-S2
http://www.cadencesound.com/products/S0W10S2.html
10" Single Voice Coil 2 Ohm Subwoofer
Specifications:
• RMS Power Handling: 200 Watts
• PEAK Power Handling: 400 Watts
• Frequency Response: 31Hz – 1 kHz
• Sensitivity: 91dB @ 1w/1m SPL
• System Impedance: 2 Ohm SVC
• Mounting Depth: 4.50” (116mm)
S0W10-S4
http://www.cadencesound.com/products/S0W10S4.html
10" Single Voice Coil 4 Ohm Subwoofer
Specifications:
• System Impedance: 4 Ohm SVC
S0W12-S2
http://www.cadencesound.com/products/S0W12S2.html
12" Single Voice Coil 2 Ohm Subwoofer
Specifications:
• RMS Power Handling: 250 Watts
• PEAK Power Handling: 500 Watts
• Frequency Response: 28Hz – 1 kHz
• Sensitivity: 93dB @ 1w/1m SPL
• Mounting Depth: 5.20” (132mm)
S0W12-S4
http://www.cadencesound.com/products/S0W12S4.html
12" Single Voice Coil 4 Ohm Subwoofer
Specifications:
S1W10-D2
http://www.cadencesound.com/products/S1W10D2.html
10" Dual Voice Coil 2 Ohm Subwoofer
Specifications:
• RMS Power Handling: 350 Watts
• PEAK Power Handling: 700 Watts
• Frequency Response: 27Hz – 750Hz
• Sensitivity: 92dB @ 1w/1m
• System Impedance: 2 Ohm DVC
• Mounting Depth: 5.02” (127.5mm)
S1W10-D4
http://www.cadencesound.com/products/S1W10D4.html
10" Dual Voice Coil 4 Ohm Subwoofer
Specifications:
• System Impedance: 4 Ohm DVC
S1W12-D2
http://www.cadencesound.com/products/S1W12D2.html
12" Dual Voice Coil 2 Ohm Subwoofer
Specifications:
• RMS Power Handling: 450 Watts
• PEAK Power Handling: 900 Watts
• Frequency Response: 26Hz – 750Hz
• Sensitivity: 94dB @ 1w/1m
• Mounting Depth: 5.71” (145mm)
S1W12-D4
http://www.cadencesound.com/products/S1W12D4.html
12" Dual Voice Coil 4 Ohm Subwoofer
Specifications:
S1W15-D2
http://www.cadencesound.com/products/S1W15D2.html
15" Dual Voice Coil 2 Ohm Subwoofer
Specifications:
• RMS Power Handling: 600 Watts
• PEAK Power Handling: 1200 Watts
• Frequency Response: 25Hz – 750Hz
• Sensitivity: 95dB @ 1w/1m
• Mounting Depth: 6.61” (168mm)
S1W15-D4
http://www.cadencesound.com/products/S1W15D4.html
15" Dual Voice Coil 4 Ohm Subwoofer
Specifications:
S1W8-D2
http://www.cadencesound.com/products/S1W8D2.html
8" Dual Voice Coil 2 Ohm Subwoofer
Specifications:
• Frequency Response: 28Hz – 750Hz
• Sensitivity: 90dB @ 1w/1m
• Mounting Depth: 3.7” (94.2mm)
S1W8-D4
http://www.cadencesound.com/products/S1W8D4.html
8" Dual Voice Coil 4 Ohm Subwoofer
Specifications:
S2W8-S2
http://www.cadencesound.com/products/S2W8S2.html
8" Single Voice Coil 2 Ohm Subwoofer
Specifications:
• RMS Power: 500 Watts
• PEAK Power: 1000 Watts
• Frequency Response: 20Hz – 500Hz
• Mounting Depth: 5.2”
S2W8-S4
http://www.cadencesound.com/products/S2W8S4.html
8" Single Voice Coil 4 Ohm Subwoofer
Specifications:
S2W10-D2
http://www.cadencesound.com/products/S2W10D2.html
10” Dual 2 Ohm Voice Coil Subwoofer
Specifications:
• RMS Power: 600 Watts
• PEAK Power: 1200 Watts
• Frequency Response: 25Hz – 500Hz
• SPL @ 1w/1m: 91dB
• Mounting Depth: 6.02” (153mm)
S2W10-D4
http://www.cadencesound.com/products/S2W10D4.html
10” Dual 4 Ohm Voice Coil Subwoofer
Specifications:
• SPL @ 1w/1m: 91dB
S2W12-D2
http://www.cadencesound.com/products/S2W12D2.html
12” Dual 2 Ohm Voice Coil Subwoofer
Specifications:
• SPL @ 1w/1m: 93dB
• Mounting Depth: 6.50” (165mm)
S2W12-D4
http://www.cadencesound.com/products/S2W12D4.html
12” Dual 4 Ohm Voice Coil Subwoofer
Specifications:
• SPL @ 1w/1m: 93dB
S2W15-D2
http://www.cadencesound.com/products/S2W15D2.html
15” Dual 2 Ohm Voice Coil Subwoofer
Specifications:
• RMS Power: 800 Watts
• PEAK Power: 1600 Watts
• SPL @ 1w/1m: 94dB
• Mounting Depth: 8.35” (212mm)
S2W15-D4
http://www.cadencesound.com/products/S2W15D4.html
15” Dual 4 Ohm Voice Coil Subwoofer
Specifications:
• SPL @ 1w/1m: 94dB
Изменено пользователем Илья 37
