продано A/D/S 450MX
DM101
Power output(Watts)* - 4 channel 4X 50Watt(minimum)
3 channel 2X50Watt,1X150(minimum)
2 channel 2X 150Watt(minimum)
Power output(Watts)* on 2 ohm load 4X 80(minimum)
*Input voltage at 13,8 VDC and <0.1%THD
Power babdwith 10Hz to 50kHz,-1.5 dB
Signal to noise ratio 115dB
Input impedance 50k Ohms
Idle current 2A
Dimensions 268mm W X 294mm L X 59mm H
