DM101 Опубликовано 14 июля, 2019 Ссылка на тему Поделиться Опубликовано 14 июля, 2019 Continuous Power Rating (Competition Standard) – Measured at 13.8V RMS continuous power per channel, all channels 20 Watts driven into a 4W load from 20-20,000Hz with less than 0.05% Total (THD) RMS continuous power per channel, all channels 40 Watts driven into a 2W load from 20-20000Hz, with less than 0.1% Total Harmonic Distortion (THD) RMS continuous power bridged x 2 into a 4W load 80 Watts from 20-20000Hz, with less than 0.1% Total Harmonic Distortion (THD) Dynamic Power Rating (IHF-202 Standard) – Measured at 14.4V 2-Channel bridged into a 4W load 120 Watts per channel into a 2W load 60 Watts per channel into a 4W load 40 Watts Signal-to-Noise Ratio (A-weighted) >100dB Factory Default Crossover Point 80Hz Butterworth (.047mf) Crossover Alignment 12dB/octave Dimensions 95⁄8"W x 139⁄32"L x 25⁄8"H (24.4cm) x (33.73cm) x (6.6cm) Damping Factor @ 4W (at output connector) >150 Bandwidth 15Hz-100kHz ±3dB Frequency Response 20Hz-20kHz ±0.5dB Slew Rate 30 V/ms IM Distortion (IHF) <0.05% Input Sensitivity Variable from 150mV to 3V Preset at the factory for 500mV B+ Fuse Size (external to amplifier) 30 amp ATC Input Impedance 20k ohms Ссылка на комментарий
