Максим55 Опубликовано 11 апреля, 2011 Ссылка на тему Поделиться Опубликовано 11 апреля, 2011 Помогите выбрать усилитель! Есть две модели RUB1.2500D Soundstream Rubicon 2500W Mono Class D Amp И SOUNDSTREAM LIL LW1.2600D MONO 5200W AMP CAR AMPLIFIER Может кто имел с ними дело хочу узнать по мощности реальные ли заявки в 2Ом и 1Ом RUB1.2500D Class D Rubicon Mono Channel Amplifier Peak Power: 5000 Watts Max RMS Power: 1 x 1700 Watts @ 2 Ohm RMS Power: 1 x 2500 Watts @ 1 Ohm THD: 0.50% Frequency Response: 15Hz - 150KHz S/N: 95dB Damping Factor: >350 Sensitivity: 100mV - 2V or 2V - 8V Low Pass Filter: 50Hz - 150Hz @ 12dB Bass Boost: 0- 18dB @ 45Hz Subsonic Filter: 10 - 40Hz @12dB Phase Control: 180 Dash Mounted Remote Gain Control Dimensions: 20.875" (L) x 8" (W) x 2" (H) Midnight Blue Finish w/ Brushed Accents Regulated MOSFET Pulse Width Modulated Power Supply Three-Way Protection Circuitry (Thermal, Short, Impedance) Twin Stack Technology TM (strap amps together for double power) Delayed On/Off Circuit Pre-Amp Output LIL LW1.2600D Soundstream LW1.2600D 1-Channel Lil Wonder III Generation Series Monoblock Class D Car Amplifier RMS Power Rating: 4 ohms: 1100 watts x 1 channel 2 ohms: 1800 watts x 1 channel 1 ohm: 2600 watts x 1 channel Max power output: 5200 watts x 1 channel Midnight Black Finish with Brushed Accents MOSFET Pulse Width Modulated Power Supply 105dB Signal-to-Noise Ratio 0.5% Total Harmonic Distortion >250 Damping Factor Variable 0-18dB 45Hz Bass Boost LED power indicator IDI Intelignet Distress Indicator (short, thermal & overload protecion) Delayed On/Off Circuit 100mV-8v Input Sensitivity Pre-Amp Output 180 Degrees Phase Shift Nickel-plated RCA level inputs Nickel-plated screw terminals Variable 12dB 50-150 Hz Low Pass Filter Frequency response: 15 Hz - 150 KHz Master / Slave Operation Twin Stack Technology (strap amps together for double power) Direct Wire 0 ga. Power, 4 ga. Speaker Terminals Remote subwoofer Level Control Included Dimensions: 23"L x 2.36"H x 8"D [sIGPIC][/sIGPIC] Ссылка на комментарий
Shocker Опубликовано 11 апреля, 2011 Ссылка на пост Ссылка на тему Поделиться Опубликовано 11 апреля, 2011 Лил версия вроде обсуждали, вроде как не ахти, посмотри в поиске, разумеется завышены. Ссылка на комментарий
Максим55 Опубликовано 11 апреля, 2011 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 11 апреля, 2011 HIFONICS HFi2500D 2500W RMS, CLASS-D MONOBLOCK HFi-Series AMPLIFIER HFi Series Single Channel Class D Car Amplifier RMS Power Rating: 4 ohms: 850 watts x 1 chan. 2 ohms: 1700 watts x 1 chan. 1 ohms: 2500 watts x 1 chan. Max power output: 2500 watts Pulse Width Modulated (PWM) MOSFET power supply LED power (blue) and protect (red) indicators Wired HFR-3 remote bass level control included Variable Bass Boost (0 to +10 dB bass boost at 45 Hz) Blue illuminated Hifonics badge Soft start sound function Mono channel operation Preamp RCA outputs to daisy chain multiple amps 4-Way System Protection circuitry (thermal, overload, DC, and speaker short protection) Dual 12 gauge speaker terminals simplify hookup Heavy duty aluminum alloy vented heatsink for maximum heat dissipation Silver nickle-plated RCA level inputs Silver nickle-plated screw terminals Input sensitivity: Variable level: 200mV-6V Variable low-pass filter (30-250 Hz, 24 dB/octave) Subsonic filter (15-35 Hz) Damping factor: >200 Frequency response: 15-250 Hz External 250A fuse required and sold separately Dimensions: 19-3/4"L x 8-13/16"W x 2-7/16"H [sIGPIC][/sIGPIC] Ссылка на комментарий
Shocker Опубликовано 11 апреля, 2011 Ссылка на пост Ссылка на тему Поделиться Опубликовано 11 апреля, 2011 (изменено) Максим55 сказал: HIFONICS HFi2500D 2500W RMS, CLASS-D MONOBLOCK HFi-Series AMPLIFIER HFi Series Single Channel Class D Car Amplifier RMS Power Rating: 4 ohms: 850 watts x 1 chan. 2 ohms: 1700 watts x 1 chan. 1 ohms: 2500 watts x 1 chan. Max power output: 2500 watts Pulse Width Modulated (PWM) MOSFET power supply LED power (blue) and protect (red) indicators Wired HFR-3 remote bass level control included Variable Bass Boost (0 to +10 dB bass boost at 45 Hz) Blue illuminated Hifonics badge Soft start sound function Mono channel operation Preamp RCA outputs to daisy chain multiple amps 4-Way System Protection circuitry (thermal, overload, DC, and speaker short protection) Dual 12 gauge speaker terminals simplify hookup Heavy duty aluminum alloy vented heatsink for maximum heat dissipation Silver nickle-plated RCA level inputs Silver nickle-plated screw terminals Input sensitivity: Variable level: 200mV-6V Variable low-pass filter (30-250 Hz, 24 dB/octave) Subsonic filter (15-35 Hz) Damping factor: >200 Frequency response: 15-250 Hz External 250A fuse required and sold separately Dimensions: 19-3/4"L x 8-13/16"W x 2-7/16"H вот этот будет лучше. Случайно спасибо поставил) Изменено 11 апреля, 2011 пользователем Shocker Ссылка на комментарий
Максим55 Опубликовано 12 апреля, 2011 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 12 апреля, 2011 HIFONICS BRZ 2400.1D 1 CH MONO AMP - 2400W (RMS) POWER RMS Power (4 ohms) 850 watts x 1 channel RMS Power (2 ohms) 1700 watts x 1 channel RMS Power (1 ohm) 2400 watts x 1 channel Total RMS Power Output 2400 watts Minimum Impedance Unbridged 1 ohms Maximum Input Gauge Size 1/0 THD at Rated RMS Power <0.1% •Brutus Series Monoblock Class D Car Amplifier •MOSFET power supply •Wired HFR-3 remote bass level control included •LED power (green) and protect (red) indicators •Variable Bass Boost (0 to +10 dB bass boost at 45 Hz) •Mono channel operation •Preamp RCA outputs to daisy chain multiple amps •4-Way System Protection circuitry (thermal, overload, speaker short and DC protect) •Heavy duty aluminum alloy finned heatsink for maximum heat dissipation •Silver-plated unbalanced RCA level inputs •Input Level (Balanced): 0.02V-6V •Variable low-pass filter (35-250 Hz, 24 dB/octave) •Subsonic filter (15-35 Hz, 24 dB/octave) •Phase Shift: 0-180° •Frequency response: 35-250 Hz •Damping factor: >290 •Dimensions: 19-3/4"L x 9-1/4"W x 2-7/16"H Preamp Outputs 1 pair High-Pass Crossover Frequency N/A Low-Pass Crossover Frequency 35 - 250 Hz Signal-to-Noise Ratio >95 dB Subsonic Filter 15 - 35 Hz Bass Boost 0 - 10 dB Есть ли в одном из этих усилителей заявленная мощность? :flag_of_truce: [sIGPIC][/sIGPIC] Ссылка на комментарий
faralint Опубликовано 12 апреля, 2011 Ссылка на пост Ссылка на тему Поделиться Опубликовано 12 апреля, 2011 Последний лучше, там сертификат о заявленой мощности который к рокфордам прикладывают DC Audio. 150+ седан. 30hz Ссылка на комментарий
