Soundstream Reference 4.920
Dammed
This amplifier is used, but it looks pretty good. There are a few very small scratches but nothing on the face/front. I'm using the amplifier to power a set of Infinity Kappa Perfect 6.1 actively without any passive crossovers. I used the crossovers on the amplifier. And the sound is really good, it plays loud and clear.
Specifications:
Power output:
160 Watts RMS x 4 @ 4 ohms
230 Watts RMS x 4 @ 2 ohms
460 Watts RMS x 2 Bridged @ 4 ohms
Regulated MOSFET power supply
RUBI (Rapid-use branched impulse) proprietary power supply technology
STACT (stabilized apex current technology) reduces power supply stress by 50%
Trident amplifier power technology
Auto high-current, regulates power supply load for application
Triple darlington output circuitry
Hawkins bass control: proprietary bass equalization
Drive delay II eliminates turn-on & turn-off pops
Ultra-low ESR capacitors for rapid power delivery & dynamic transient peaks
Tri-mode operation
Damping Factor: >1000
Signal-to-noise ratio: >110dB
180 degree phase control
30-80hz hawkins bass boost
200mV-9V input voltage
4ga. Power & 8ga direct wire terminal
Dimensions: H: 2.25" x W: 9.875" x L: 23.75"
Price: 16000RUB
