Продам AQ3500D.1 Amplifier
shmel
Продам добрый усилок бу, не вскрывался, не ремонтировался,
1 ohm power @ 14.4V @ < 1% THD 4300W x 1
цена 30000р, отправка за ваш счет
связь личка, аська 258555003, т 89127637112
торгуемо, отправка без проблем по РФ, 1 хозяин, приобретался новым у официалов, полный комплект
Изменено пользователем shmel
Model AQ3500D.1
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2V ~ 5V
Variable Low Pass Filter 20Hz ~ 200Hz
@ 24dB/Slope
Subsonic Filter 10Hz ~ 50Hz @ 24dB/
Slope
2 amp linkable connection Output
Master / Input Slave
Remote Gain Control yes
Clipping Display Led yes
Signal to Noise Ratio 85dB <
Damping Factor 250 <
Efficiency 85% at 4 ohm <
External Fuse Rating 380 Amp in-line,
760 for pair
Tested Voltage 14.4V
Working Voltage 9.5V ~ 18.5V**
4 ohm power @ 12V @ 1% THD 750W
x 1
4 ohm power @ 14.4V @ 1% THD
1400W x 1
2 ohm power @ 14.4V @ 1% THD
2600W x 1
4300W x 1
1 ohm Power @ 16V** @ 1% THD
5300W x 1
1 ohm Power @ 18V** @ 1% THD
6000W x 1
1 ohm Power @ 18V** @ 10% THD
7500W x 1
2 ohm Linked Power @ 14.4V @ 1%
THD 8600W x 1
2 ohm Linked Power @ 16V** @ 1%
THD 10600W x 1
2 ohm Linked Power @ 18V** @ 1%
THD 12000W x 1
2 ohm Linked Power @ 18V** @ 10%
THD 15000W x 1
Dimensions (mm) 657.2mm (L) x
241.3mm (W) x 66.7mm (H)
Dimensions (in) 25.875in (L) x 9.5in
(W) x 2.625in (H)
Power and Ground Inputs 0 Guage x
2
