Skar Audio T-1400.1D
atikhobaev
Skar Audio T Series T1400.1D 1400W Monoblock Class D Sub Amplifier
В идеальном состоянии
Цена 12 000 руб
RMS Power @ 1 Ohms : 1400 Watts x 1 CH
RMS Power @ 2 Ohms : 700 Watts x 1 CH
RMS Power @ 4 Ohm : 350 Watts x 1 CH
Input Sensitivity : 6v~0.2v
Low Pass Filter (variable) : 50Hz ~ 250Hz
Subsonic Filter (variable) : 15Hz ~ 50Hz
Frequency Response (-3dB) : 10Hz ~ 250Hz
Bass Boost (variable) : 0dB ~ +12dB
Signal to Noise Ratio : 100dB
Damping Factor : 180 Degrees
1 Ohm Stable
Fuse Rating : 40 Amp x 3
Line-In RCA Connection
Line-Out RCA Connection
Dimensions : 250mm Wide x 53mm High x 340mm Long
