СT Sounds AT-7000.1D
Васиф
Обратите внимание что заявка снята с 12.8v а не с 14.4:good:
Ratings
1 Ohm @ 12.8v 7000w rms l 14000w max
2 Ohms @ 12.8v 3500w rms l 7000w max
4 Ohms @ 12.8v 1750w rms l 3500w max
Technical Specs
Frequency response 10hz to 250hz
Gain adjustment 0.2v to 5v
Subsonic adjustment 10hz to 50hz
Phase adjustment 0º to 180º
Bass boost 0dB to 18 dB
Signal to noise 100 dB
Damping factor 180
Minimum impedance 1 Ohm
Low pass filter 35hz to 250hz
Strappable master/slave switch
Dimensions 794mm x 70mm x 330mm
Foot Print 794mm x 330mm
Bass knob Remote gain Control
Clip light Indicator
Built in volt meter
Pushable on-off switch
Sparta Team
