Популярный пост Илья 37 Опубликовано 10 ноября, 2010 Популярный пост Ссылка на тему Поделиться Опубликовано 10 ноября, 2010 (изменено) Midranges CVL-64MBX http://www.cadencesound.com/products/CVL64MBX.html Specifications: • Cast Aluminum Basket • Impedance: 4 Ohm • Accordion Style Surround • RMS Power: 250 Watts • PEAK Power: 500 Watts • Frequency: 135Hz – 10.5 kHz • Structure Weight: 70oz • Sound Pressure Level: 99dB @ 1w/1m • Mounting Depth: 3.42” CVL-68MBX http://www.cadencesound.com/products/CVL68MBX.html Specifications: • RMS Power: 250 Watts • PEAK Power: 500 Watts • Frequency: 90Hz – 9 kHz • Structure Weight: 70oz • Sound Pressure Level: 99dB @ 1w/1m • Impedance: 8 Ohm • Mounting Depth: 3.42” CVL-84MBX http://www.cadencesound.com/products/CVL84MBX.html Specifications: • Cast Aluminum Basket • Impedance: 4 Ohm • Accordion Style Surround • RMS Power: 250 Watts • PEAK Power: 500 Watts • Frequency: 102Hz – 10 kHz • Structure Weight: 90oz • Sound Pressure Level: 102dB @ 1w/1m • Mounting Depth: 3.58” CVL-88MBX http://www.cadencesound.com/products/CVL88MBX.html Specifications: • RMS Power: 250 Watts • PEAK Power: 500 Watts • Frequency: 60Hz – 8 kHz • Structure Weight: 90oz • Sound Pressure Level: 102dB @ 1w/1m • Impedance: 8 Ohm • Mounting Depth: 3.58” CVLM-1054 http://www.cadencesound.com/products/CVLM1054.html мидбас, 254mm, сопротивление 4Ом, мощность 150Вт RMS / 300Вт MAX, SPL 100дБ+, частотный диапазон 60Гц-4кГц CVLM-1058 http://www.cadencesound.com/products/CVLM1058.html Specifications: • RMS Power: 150 Watts • PEAK Power: 300 Watts • Frequency Response: 60Hz – 4 kHz • Sound Pressure Level: 100dB+ @ 1w/1m • Structure Weight: 50oz • Impedance: 8 Ohm • Mounting Depth: 3.23” CVLM-64 http://www.cadencesound.com/products/CVLM64.html мидбас, 165mm, 70Вт RMS / 140Вт MAX, SPL 98дБ+, 4Ом, 100Гц-7кГц, стальная корзина, уст.глубина 2,03" CVLM-64N http://www.cadencesound.com/products/CVLM64N.html Specifications: • RMS Power: 100 Watts • PEAK Power: 200 Watts • Frequency Response: 105Hz – 7 kHz • Sound Pressure Level: 93dB+ @ 1w/1m • Impedance: 4 Ohm • Mounting Depth: 2.00” CVLM-68 http://www.cadencesound.com/products/CVLM68.html Specifications: • RMS Power: 70 Watts • PEAK Power: 140 Watts • Frequency Response: 100Hz – 7 kHz • Sound Pressure Level: 98dB+ @ 1w/1m • Structure Weight: 40oz • Impedance: 8 Ohm • Mounting Depth: 2.03” CVLM-68N http://www.cadencesound.com/products/CVLM68N.html Specifications: • RMS Power: 100 Watts • PEAK Power: 200 Watts • Frequency Response: 105Hz – 7 kHz • Sound Pressure Level: 93dB+ @ 1w/1m • Impedance: 8 Ohm • Mounting Depth: 2.00” CVLM-84 http://www.cadencesound.com/products/CVLM84.html мидбас, 200mm, 100Вт RMS / 200Вт MAX, SPL 100дБ+, 4Ом, 102Гц-10кГц, стальная корзина, уст.глубина 2,72" CVLM-84N http://www.cadencesound.com/products/CVLM84N.html мидбас, 200mm, 125Вт RMS / 250Вт MAX, SPL 93дБ+, 4Ом, 105Гц-7кГц, стальная корзина, уст.глубина 2" CVLW-64S http://www.cadencesound.com/products/CVLW64S.html мидбас, 165mm, сопротивление 4Ом, мощность 60Вт RMS / 120Вт MAX, SPL 98дБ+, частотный диапазон 135Гц-10,5кГц, литая корзина CVLW-84S http://www.cadencesound.com/products/CVLW84S.html мидбас, 200mm, сопротивление 4Ом, мощность 100Вт RMS / 200Вт MAX, SPL 100дБ+, частотный диапазон 102Гц-10кГц, литая корзина XM64HC http://www.cadencesound.com/products/XM64HC.html Specifications: • RMS Power: 75 Watts • PEAK Power: 150 Watts • Frequency Response: 150Hz – 15 kHz • Structure Weight: 60 oz • Sensitivity: 102dB @ 1w/1m SPL • Impedance: 4 Ohm • Mounting Depth: 2.20” XM68HC http://www.cadencesound.com/products/XM68HC.html Specifications: • RMS Power: 75 Watts • PEAK Power: 150 Watts • Frequency Response: 150Hz – 15 kHz • Structure Weight: 60 oz • Sensitivity: 102dB @ 1w/1m SPL • Impedance: 8 Ohm • Mounting Depth: 2.20” XM64V http://www.cadencesound.com/products/XM64V.html 6.5” Midrange Driver Specifications: • RMS Power: 75 Watts • PEAK Power: 150 Watts • Frequency Response: 125Hz – 10 kHz • Structure Weight: 60 oz • Sensitivity: 100dB @ 1w/1m SPL • Impedance: 4 Ohm • Mounting Depth: 2.20” XM68V http://www.cadencesound.com/products/XM68V.html 6.5” Midrange Driver Specifications: • RMS Power: 75 Watts • PEAK Power: 150 Watts • Frequency Response: 125Hz – 10 kHz • Structure Weight: 60 oz • Sensitivity: 100dB @ 1w/1m SPL • Impedance: 8 Ohm • Mounting Depth: 2.20” XM694 http://www.cadencesound.com/products/XM694.html 6" x 9" Midrange Driver Specifications: • RMS Power Handling: 125 Watts • PEAK Power Handling: 250 Watts • Frequency Response: 150Hz – 10 kHz • Sensitivity: 102dB @ 1w/1m • Impedance: 4 Ohm • Mounting Depth: 3.15” XM84HC http://www.cadencesound.com/products/XM84HC.html 8” High Compression Driver Specifications: • RMS Power: 125 Watts • PEAK Power: 250 Watts • Frequency Response: 100Hz – 17 kHz • Structure Weight: 90 oz • Sensitivity: 103dB @ 1w/1m SPL • Impedance: 4 Ohm • Mounting Depth: 2.60” XM88HC http://www.cadencesound.com/products/XM88HC.html 8” High Compression Driver Specifications: • RMS Power: 125 Watts • PEAK Power: 250 Watts • Frequency Response: 100Hz – 17 kHz • Structure Weight: 90 oz • Sensitivity: 103dB @ 1w/1m SPL • Impedance: 8 Ohm • Mounting Depth: 2.60” XM84V http://www.cadencesound.com/products/XM84V.html 8” Midrange Driver Specifications: • RMS Power: 125 Watts • PEAK Power: 250 Watts • Frequency Response: 100Hz – 11 kHz • Structure Weight: 90 oz • Sensitivity: 102dB @ 1w/1m SPL • Impedance: 4 Ohm • Mounting Depth: 2.60” XM88V http://www.cadencesound.com/products/XM88V.html 8” Midrange Driver Specifications: • RMS Power: 125 Watts • PEAK Power: 250 Watts • Frequency Response: 100Hz – 11 kHz • Structure Weight: 90 oz • Sensitivity: 102dB @ 1w/1m SPL • Impedance: 8 Ohm • Mounting Depth: 2.60” XM88 http://www.cadencesound.com/products/XM88.html 8” Midrange Driver Specifications: • RMS Power: 100 Watts • PEAK Power: 200 Watts • Frequency Response: 102Hz – 10 kHz • Structure Weight: 80 oz • Sensitivity: 100dB @ 1w/1m SPL • Impedance: 8 Ohm • Mounting Depth: 3.15” Tweeters CVLT-10 http://www.cadencesound.com/products/CVLT10.html Титановый супер твитер, 25mm, сопротивление 4Ом, мощность 100Вт RMS / 200Вт MAX, SPL 96дБ+, частотный диапазон: 1,4кГц-25кГц CVLT-50 http://www.cadencesound.com/products/CVLT50.html твитер, 50mm, сопротивление 6Ом, мощность 50Вт RMS / 100Вт MAX, SPL 107дБ+, частотный диапазон 2Гц-25кГц CVLT-60 [uR]http://www.cadencesound.com/products/CVLT60.html[/url] твитер, 25mm, сопротивление 3Ом, мощность 50Вт RMS / 100Вт MAX, SPL 109дБ+, частотный диапазон 3Гц-20кГц Всем доброго времени суток! По наличию: популярные позиции есть в наличии! Что-то под заказ, буду стараться все привозить в кротчайшие сроки! По всем вопросам в личку! Для особо отчаянных можно привезти 8 омные версии динамиков! Для удобства коммутации! Все желающие пишите в личку:hi: Изменено 13 марта, 2012 пользователем Илья 37 Ссылка на комментарий
