Илья 37 Опубликовано 1 марта, 2011 Ссылка на тему Поделиться Опубликовано 1 марта, 2011 (изменено) SPL LINE Sound Pressure Level Subwoofer Dual voice coil Vented die-cast basket Dual oversized Nomex spider Sewn-in tinsel leads GFP 123 fiberglass cone Fiberglass dust cap SPL 15 15”/38cm 2x 1650/1100 Watt Peak-Power > 65 Hz : 15 000 Watt 2x 1 ohm impedance High-Power 4” flat wire voice coil Vented box 90-130 l http://www.gladen.com/GladenWooferPDFs/SPL15.pdf SPL 12 12”/30cm 2x 1350/900 Watt Peak-Power > 65 Hz : 12 000 Watt 2x 1 ohm impedance High-Power 4” flat wire voice coil Vented box 60-80 l http://www.gladen.com/GladenWooferPDFs/SPL12.pdf SPL COMPETITION LINE 100% SPL Competition Woofer High-Power 4”flat wire voice coil Made in USA Dual oversized Nomex spider Sewn-in tinsel leads Rigid Kevlar cone, made in Europe Custom built in Germany SPL 15 COMPETITION 15”/38cm Peak-Power > 65 Hz : 30 000 Watt Impedance according to customer request 2x 0,5/0,7/1,0 ohm SPL 12 COMPETITION 12”/30cm Peak-Power > 65 Hz : 25 000 Watt Impedance according to customer request 2x 0,5/0,7/1,0 ohm ZERO PRO LINE High-End Subwoofer Vented die-cast basket Nomex spider Lasercut back-plate Sewn-in tinsel leads GLADEN PFP Technology: paper/foam/paper compound cone Made in Germany ZERO 12 PRO 12”/30cm 750/500 Watt 4 ohm impedance 2,5” voice coil Vented box 50 l or sealed box 30 l ZERO 10 PRO 10”/25cm 600/400 Watt 4 ohm impedance 2,5” voice coil Vented box 30 l or sealed box 20 l SQL LINE Sound Quality Level Subwoofer Vented die-cast basket Dual oversized Nomex spider Sewn-in tinsel leads Rigid paper cone Fiberglass dust cap SQL 15 15”/38cm 1800/1200 Watt 4 ohm impedance Flat wire high-power 4” voice coil Vented box 90-120 l http://www.gladen.com/GladenWooferPDFs/SQL15.pdf SQL 12 12”/30cm 1650/1100 Watt 4 ohm impedance Flat wire high-power 4” voice coil Vented box 50-60 l or band-pass enclosure http://www.gladen.com/GladenWooferPDFs/SQL12.pdf SQX LINE High Performance Subwoofer Vented die-cast basket Black Nomex spider Dual Spider (12”) Sewed lead wire paper cone SQX 12 12”/30cm 900/600 Watt 4 ohm impedance 3” voice coil Vented box 45-55 l or sealed box 30-35 l SQX 10 10”/25cm 525/350 Watt 4 ohm impedance 2,5” voice coil Vented box 30-35 l or sealed box 22-28 l SQX 08 8”/20 cm 375/250 Watt 4 ohm impedance 2” voice coil Vented box 18-21 l or sealed box 12-15 l RS LINE All-round Subwoofer Vented die-cast basket Black Nomex spider Sewn-in tinsel leads Paper cone Fiberglass dust cap RS 12 12”/30 cm 600/400 Watt 4 ohm impedance 2,5” voice coil Vented box 48 l or sealed box 32 l http://www.gladen.com/GladenWooferPDFs/RS12.pdf RS 10 10”/25 cm 375/250 Watt 4 ohm impedance 2” voice coil Vented box 32 l or sealed box 22 l http://www.gladen.com/GladenWooferPDFs/RS10.pdf RS 08 8”/25 cm 250/175 Watt 4 ohm impedance 1,5” voice coil Vented box 18 l or sealed box 12 l http://www.gladen.com/GladenWooferPDFs/RS08.pdf RS LINE CABINETS Vented Enclosures High-strength MDF Airflow optimized port Black carpet finish RS 12-VB RS 12 Subwoofer 600/400 Watt 4 ohm impedance 670x400x180/340mm (48 l) RS 10-VB RS 10 Subwoofer 375/250 Watt 4 ohm impedance 550x360x200/320mm (32 l) RS 08-VB RS 08 Subwoofer 250/175 Watt 4 ohm impedance 370x280x210/310mm (18 l) RS Free-Air LINE Free-Air Subwoofer Vented die-cast basket Black Nomex spider Sewn-in tinsel leads Paper cone Fiberglass dust cap RS 15 Free-Air 15”/38 cm 650/450 Watt 4 ohm impedance 2,5” voice coil http://www.gladen.com/GladenWooferPDFs/RS15FA.pdf RS 12 Free-Air 12”/30 cm 600/400 Watt 4 ohm impedance 2,5” voice coil http://www.gladen.com/GladenWooferPDFs/RS12FA.pdf M-LINE High-Efficiency Subwoofer Black Nomex spider Sewn-in tinsel leads Paper cone Fiberglass dust cap M 15 15”/38 cm 600/400 Watt 4 ohm impedance 2,5” voice coil Vented/closed box or Free-Air http://www.gladen.com/GladenWooferPDFs/M15GLADEN.pdf M 12 12”/30 cm 450/300 Watt 4 ohm impedance 2” voice coil Vented box 48 l or sealed box 32 l http://www.gladen.com/GladenWooferPDFs/M12GLADEN.pdf M 10 10”/25 cm 300/200 Watt 4 ohm impedance 2” voice coil Vented box 32 l or sealed box 20 l http://www.gladen.com/GladenWooferPDFs/M10Gladen.pdf M-LINE CABINETS Vented Enclosures High-strength MDF Airflow optimized port Black carpet finish M 12-VB M 12 Subwoofer 450/300 Watt 4 ohm impedance 670x400x180/340mm (48 l) M 10-VB M 10 Subwoofer 300/200 Watt 4 ohm impedance 550x360x200/320mm (32 l) Изменено 2 февраля, 2012 пользователем Илья 37 Ссылка на комментарий
