Новый Alpine TYPE-R
Кто что слышал о нем, стоит брать?
Features:
12" Dual 2 ohm Type R Subwoofer
Power Handling:
Peak: 1800 watts
RMS: 300-600 watts
Kevlar reinforced pulp cone woofer
2-Piece Structural Parabolic diaphragm design
Injection molded Santoprene rubber surround
Alpine exclusive High Amplitude Multi-Roll (H.A.M.R) surround for impressive excusrion and clean, accurate bass
FEA Optimized progressive NOMEX spider
Radial vented VC head sink
Concealed mount gasket system
Reinforced layer spider integration tinsel leads
Oversized 2-1/2" Voice coil
4-Layer dual voice coil design
Voice coil made from 180°C high temperature wire on spiral cut aluminum former
Single-piece cast aluminum frame with Alpine Patent Pending Airflow Management System for efficient cooling
Airflow Management system controls the temperature of the voice coil by directing the air across the heatsink
One sided push terminals make installation and wiring fast and simple
Each terminal accepts up to 8 AWG wire for high power signal transfer
Concealed gasket mounting system hides the screw holes and makes for a clean install
Integrated grill technology allows for a seamless installation of a grill
US Patented Compound Radius Curve (CRC) design with integrated short sleeve configuration
CRC Machined motor structure creates a symmetrical magnetic field for less distortion and improves power handling
High-power, double-stacked strontium magnet structure
Newly redesigned for a 20% depth reduction
Frequency response: 24-200 Hz
Sensitivity: 83 dB
  • Ответов 39
катуха уже 2,5дюйма...весело но чет рмс 300ватт не возбуждает
p88rsII,6nd410,e8-100s х-2,st1,f4.600,f2.300,f2.500,q12
Мне в нем понравилось то, что (как уже заметил Denzel), катушка 2,5 дюйма и нормальная система вентиляции.
А чо чуйка такая низкая?:cray:
да она и была некакая не удивлюсь если и 83дб завышенная :sarcastic:
надо его купить...спалить... и отправить бассхэду:) с просбой выложить инфу о дине всем на обозрение:)
Team Bitcoin Bassclub
удачи в преобретении....и чтоб все быстро к басхеду пришло
очень напрягают 2 момента во всей этой новой конструкции:
1.при увеличенном до 2,5 дюйма диаметре катушки остаётся меньше места для шайб,количество полуволн уже будет меньше,разумеется это не лучшим образом скажется на линейности.
2.при таком же размере магнита создавать в зазоре поле для 2,5" катушки значительно сложнее,нежели для 2",поле "размажется" по более длинному зазору,так что неудивительно,что чутья толком нет.Да и масса подвижки подросла скорее всего.
Надо ждать когда у нас появиться, будет на порядок дешевле!
о да :rofl2::yahoo:
GZPW 15XQ + GZPA 1.10000 :blush:
