Новый Rockford T2 Power Series
VENOM
Лазил по ютубу и наткулся на новый рокфорд Т2, он черного цвета
И заявленая мощя 1200\2400 ватт
Вот описание на ангийском
15" Dual 4 ohm T2 Power Series Subwoofer
Power Handling:
Peak: 2400 watts
RMS: 1200 watts
Impedance: Dual 4 ohm
Hard anodized aluminum dustcap and cone
High excursion Thermo-Rubber Santoprene surround
Mirror image symmetrical tear and fatigue resistant poly cotton spider
Parabolic triangular cone geometry support system
Precision cast and vented aluminum alloy basket and rigid frame
Optimized motor magnetics with extended vented pole and bumped backplate
Die-cast motor case and heatsink
Removable and reversible screw concealing ring
Ultra-high temp anodized aluminum voice coil and former
Fatigue resistant and reduced strain "stitched on" flexible lead wire design
Multi-point high-temp/high-strength neck joint bonding technique
Spun-laced Nomex insulating reinforcement collar
(IDHS) Inductive Damping Heat Sink
Custom insulated/isolated compression input terminal assembly
Flat edge wound copper clad aluminum wire
Triple stacked ferrite magnet structure
Sensitivity: 85.4 dB
CEA-2031 Compliant
1-year SonicElectronix.com warranty
Package Includes:
Power DVC Subwoofer
Trim Ring
4 Socket Head Trim Ring Screws
8 Socket Head Wood Screws
Socket Head Driver Bit
Installation and Operation Manual
Subwoofer Specifications
Subwoofer Size 15"
Subwoofer Design Round / Circle
Main Cone Color Black
Voice Coil(s) Dual (2 voice coils)
Impedance (per voice coil) 4 ohms
Peak Power Handling 2400 watts
RMS Power Handling 1200 watts
Woofer Composition Anodized Aluminum
Woofer Surround Thermo-Rubber
Minimum Sealed Box Volume N/A
Maximum Sealed Box Volume N/A
Minimum Ported Box Volume 2.75 cubic feet
Maximum Ported Box Volume 3.25 cubic feet
Sensitivity 85.4 dB
Frequency Response N/A
Xmax (millimeters) 19 mm
Top Mount Depth 9-7/8"
Shallow Mount Installation No
Cutout Diameter 13-13/16"
Recommended Enclosure Type Ported / Vented
Subwoofer Grille No
Re-Cone Kit Available No
Вот видео:
Известно кому что либо ещё о этих сабах?
Изменено пользователем VENOM
vk.com/club11175258
vk.com/bassmechanix
Я думаю такой же как и старый Т2 - трудный для давилова и монстр на музыке!)
Team DD Russia
вентиляция по ходу улучшена...
да и старый очень тяжело перегреть.
S-A - 151.5 - 2010 г.
Stock 1- 153 Db Чемпион IASCA 2010 г.
Т2 тяжело раскачать или он плохо давит?
Ну я думаю он даже немного лучьше р-ки должен давить, хотя - это можно долго спорить
И ваще по идее же Т2 - это ведь живучие сабы для повседнева на нигеров???
vk.com/club11175258
vk.com/bassmechanix
у эрки маленький зазор ,катуха 2.5" из-за чего чуйка и бл высокие вот и залог того что столько резов на ней хороших,у т2 катуха 4" зазор побольше ,давить на нём не-то... чуйки вообще нет ему надо пару честных киловат на повседнве и играть негров 30-40гц,от одинаковой мощи у эрки рез будет выше намного, зато у рокфорда громкие негры будут не заканчиваться:wink:
152@30Hz
Так чуйка у них одинаковая, у меня друг давил на Т2 15-шках занал первое место на финале ЕММА - Сказал сабы офигенные и крепкие, качал их рокфордом 4000
Думаю новая модель должна неплохо себя показать, ведь щяс много конкурентно-способных фирм, которые выпускают сабы
Интересно когда новые Т2 появятся в России?
vk.com/club11175258
vk.com/bassmechanix
Ну если много маленьких окошек по радиусу на магните для вентиляция, то скорей всего и улучшена! Во всем остальном точно такой же вид корзины!
Team DD Russia
у т2 есть ряд недостатков...
1 цена
2 маленькая эффективная площадь(столько же как у жиэля 13в7)
3 тяжёленький малеха
Всё остальное в плюс...
А кто такой прям интересно ?
Денис STRADIVARI ORIGINAL
т2 катуха 4 дюйма??
Это получается даже больше чем у DC level 4xl, там 3 дюйма но зато 8 слоёв :smile:
И ваще Т2 пянтахи низы басса хорошо воспроизводят?
vk.com/club11175258
vk.com/bassmechanix
т2 катуха 4 дюйма??
низы да! только настроечку на 33-35гц делай и кайфуй::hair::
152@30Hz
Ну так...
Можно прям из первых уст унать:smile:
