RockMan Опубликовано 10 декабря, 2014 Ссылка на тему Поделиться Опубликовано 10 декабря, 2014 (изменено) Cadence Chicago 4 Ohm RMS Power: 90 Watts x 4 2 Ohm RMS Power: 140 Watts x 4 4 Ohm Bridged RMS Power: 280 Watts x 2 • Low Pass: 40 Гц - 150 Гц • High Pass: 50 Гц - 500 Гц Cadence Vegas 4 Ohm RMS Power: 135 Watts x 4 2 Ohm RMS Power: 225 Watts x 4 4 Ohm Bridged RMS Power: 450 Watts x 2 • Low Pass: 40Hz – 150Hz • High Pass: 50Hz – 500Hz Cadence Dakota 4 Ohm RMS Power: 400 Watts x 1 2 Ohm RMS Power: 600 Watts x 1 1 Ohm RMS Power: 1200 Watts x 1 Cadence Olympia 4 Ohm RMS Power: 500 Watts x 1 2 Ohm RMS Power: 1000 Watts x 1 1 Ohm RMS Power: 2000 Watts x 1 Cadence Phoenix 4 Ohm RMS Power: 800 Watts x 1 2 Ohm RMS Power: 1200 Watts x 1 Cadence CSA1000.2 - 4 Ohm RMS Power: 75 Watts x 2 2 Ohm RMS Power: 150 Watts x 2 4 Ohm Bridged RMS Power: 300 Watts x 1 • Low Pass Crossover: 50Hz – 250Hz • High Pass Crossover: 120Hz – 3 kHz Cadence CSA1000.4 4 Ohm RMS Power: 150 Watts x 4 2 Ohm RMS Power: 300 Watts x 4 4 Ohm Bridged RMS Power: 600 Watts x 2 • Low Pass Crossover: 50Hz – 250Hz • High Pass Crossover: 120Hz – 3 kHz Cadence CSA3000.1 - цена 7070р 4 Ohm RMS Power: 250 Watts x 1 2 Ohm RMS Power: 500 Watts x 1 • Adjustable Bass Boost: 0 – 12dB • Adjustable Subsonic Filter: 15Hz – 55Hz • Low Pass Crossover: 50Hz – 500Hz Cadence CSA5000.1 4 Ohm RMS Power: 300 Watts x 1 2 Ohm RMS Power: 600 Watts x 1 1 Ohm RMS Power: 1200 Watts x 1 • Adjustable Bass Boost: 0 – 12dB • Adjustable Subsonic Filter: 15Hz – 55Hz • Low Pass Crossover: 50Hz – 250Hz Cadence D250.2 - 4 Ohm RMS Power: 250 Watts x 2 2 Ohm RMS Power: 400 Watts x 2 4 Ohm Bridged RMS Power: 800 Watts x 1 • Low Pass Frequencies: 45Hz - 300Hz or 450Hz - 4.5 kHz • High Pass Frequencies: 10Hz - 300Hz or 150Hz - 4.5 kHz Cadence D350.2 4 Ohm RMS Power: 350 Watts x 2 2 Ohm RMS Power: 550 Watts x 2 4 Ohm Bridged RMS Power: 1100 Watts x 1 • Low Pass Frequencies: 45Hz - 300Hz or 450Hz - 4.5 kHz • High Pass Frequencies: 10Hz - 300Hz or 150Hz - 4.5 kHz Cadence D100.4 - 4 Ohm RMS Power: 100 Watts x 4 2 Ohm RMS Power: 150 Watts x 4 4 Ohm Bridged RMS Power: 300 Watts x 2 • High Pass Frequencies: 10Hz - 300Hz or 150Hz - 4.5 kHz • Low Pass Frequencies: 45Hz - 450Hz or 450Hz to 4.5kHz Cadence D1600M - 4 Ohm RMS Power: 900 Watts x 1 2 Ohm RMS Power: 1600 Watts x 1 Cadence D1800M - цена 15740р 4 Ohm RMS Power: 600 Watts x 1 2 Ohm RMS Power: 1200 Watts x 1 1 Ohm RMS Power: 1800 Watts x 1 Cadence D2500M - 4 Ohm RMS Power: 800 Watts x 1 2 Ohm RMS Power: 1600 Watts x 1 1 Ohm RMS Power: 2500 Watts x 1 Cadence FXA1000.2 4 Ohm RMS Power:65 Watts x 2 2 Ohm RMS Power:90 Watts x 2 • High Pass Frequency: 120Hz - 3KHz • Low Pass Frequency: 50Hz - 250Hz Cadence FXA1600.2 4 Ohm RMS Power:125 Watts x 2 2 Ohm RMS Power:200 Watts x 2 • High Pass Frequency: 120Hz - 3KHz • Low Pass Frequency: 50Hz - 250Hz Cadence FXA2400.4 4 Ohm RMS Power:65 Watts x 4 2 Ohm RMS Power:90 Watts x 4 4 Ohm Bridge Power:180 Watts X 2 Cadence FXA1500.1 - 4 Ohm RMS Power: 250 Watts x 1 2 Ohm RMS Power: 400 Watts x 1 Cadence FXA2500.1D - 4 Ohm RMS Power: 300 Watts x 1 2 Ohm RMS Power: 600 Watts x 1 1 Ohm RMS Power: 900 Watts x 1 Cadence FXA-5000.5 - 4 Ohm RMS Power: 65 Watts x 1 + 150 2 Ohm RMS Power: 90 Watts x 4 + 300 4 Ohm Bridge Power: 180 Watts X 2 • High Pass Frequency: 40Hz - 3KHz • Low Pass Frequency: 40Hz - 250Hz • Subsonic Filter: 15Hz - 55Hz Изменено 25 февраля, 2015 пользователем RockMan Ссылка на комментарий
AQ_ Опубликовано 10 декабря, 2014 Ссылка на пост Ссылка на тему Поделиться Опубликовано 10 декабря, 2014 :good: Неплохо бы добавить краткие характеристики, чтобы не приходилось по каждому товару лезть в гугл и на оф. сайт. Ссылка на комментарий
RockMan Опубликовано 10 декабря, 2014 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 10 декабря, 2014 :good: Неплохо бы добавить краткие характеристики, чтобы не приходилось по каждому товару лезть в гугл и на оф. сайт. Фото и характеристики утром буду закидывать. Не успеваю все на работе делать )). Более того, скажу - цены обсуждаемы при покупке комплектов на компонентах Cadence Dragster MTX. Ссылка на комментарий
AQ_ Опубликовано 10 декабря, 2014 Ссылка на пост Ссылка на тему Поделиться Опубликовано 10 декабря, 2014 RockMan, :music: А если брать комплект фронт + саб + уси или просто фронт + саб, возможна скидка?)) Ссылка на комментарий
RockMan Опубликовано 10 декабря, 2014 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 10 декабря, 2014 AQ_, придумаем что-нибудь. На самом деле, цены тут стоят самые низкие хоть и с учетом последнего драконовского подорожания. Но, в любом случае, для соклубовцев при заказе саб+усь+фронт цены будем обсуждать в личке ))) Ссылка на комментарий
BassGain Опубликовано 11 декабря, 2014 Ссылка на пост Ссылка на тему Поделиться Опубликовано 11 декабря, 2014 Есть в этом списке толковые 4-х канальные уси для рупоров? 75-100вт на канал. Ural DB 1.3500 (2шт) + Ural Patriot 15 (4шт) Ссылка на комментарий
Crackrus21 Опубликовано 11 декабря, 2014 Ссылка на пост Ссылка на тему Поделиться Опубликовано 11 декабря, 2014 Есть в этом списке толковые 4-х канальные уси для рупоров? 75-100вт на канал. Бери Cadence D100.4, рупора сможешь резать даже с усилителя, фильтра там позволяют это сделать. Кроссовер : 24 дБ на окт. Фильтр ВЧ 1 и 2 каналов, Гц : 10 - 300 или 150 - 4500 Фильтр ВЧ 3 и 4 каналов, Гц : 15 - 500 Фильтр НЧ, Гц : 45 - 450 или 450 - 4500 PS: В свое время были у меня Cadence Olympia и Cadence D100.4, моноблок продал знакомому, а Cadence D100.4 оставил себе. Об усилителях остались только положительные впечатления! Ссылка на комментарий
RockMan Опубликовано 11 декабря, 2014 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 11 декабря, 2014 Да, Cadence D100.4, действительно, очень хороший усилитель! Развитые фильтра+мощность+звук! Еще у него есть информативный дисплей, который показывает режимы работы, напряжение и прочие параметры! Ссылка на комментарий
Irbis Опубликовано 11 декабря, 2014 Ссылка на пост Ссылка на тему Поделиться Опубликовано 11 декабря, 2014 цены выше чем у нас в городе в магазинах Ссылка на комментарий
RockMan Опубликовано 11 декабря, 2014 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 11 декабря, 2014 Irbis, скажу более того - грядет очередное подорожание. Цены обновляются каждую неделю. И, если у кого то что то осталось со старых закупок, то тут я не в силах отговорить человека продавать себе в минус. Если какие то конкретные модели интересуют - пишите в личку. На некоторые позиции можно обсуждать цены. Ссылка на комментарий
FoxRiver Опубликовано 5 января, 2015 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 января, 2015 никак не найду точную инфу есть ли у Cadence D100.4 предохранители и какой у них номинал? на буржуйском сайте было написано 1х40? там действительно 1 пред на 40 ампер? Ссылка на комментарий
Crackrus21 Опубликовано 5 января, 2015 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 января, 2015 никак не найду точную инфу есть ли у Cadence D100.4 предохранители и какой у них номинал? на буржуйском сайте было написано 1х40? там действительно 1 пред на 40 ампер? Являюсь владельцем данного уся, что то я не помню предов на усилке. Ссылка на комментарий
alex1997 Опубликовано 8 января, 2015 Ссылка на пост Ссылка на тему Поделиться Опубликовано 8 января, 2015 Стоит у нас в магазине. Встроенного преда нет. Цеплять внешний про номинал и в паспорте не указано Ссылка на комментарий
