AQ 750.1
Sun43
AQ-750, звук изумителен!
AQ- дочерняя фирма DD!!!
Выходная мощность 14.4V @ 1% THD - 300X1 @ 4ohm, 500X1 @ 2ohm, 750X1 @1ohm.
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V—16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 30Amp X 3 (Linked 180 Amp)
Output Power 14.4V @ 1% THD 300X1 @ 4 ohm,500X1 @ 2 ohm,750X1 @1 ohm
Output Power 14.4V @ 5% THD 1000X1 @ 1 ohm
Dash Mounted Remote Included
Dimensions 10.00?(L)x9.27?(W)x2.35?(H)
