Обзор SA15 от Pulse Car Audio .... или два са15+ддм3а = 151+
Skillz
http://www.stevemeadedesigns.com/board/topic/125427-2-sundown-sa15-in-a-dodge-ram-pca-style/
Though some may ASSUME that this is a comparison test... it really isn't meant to be. I have had two DD 3515 in the Dodge for a few months now. They are seriously great subs. I love them and have no plans on letting them go anywhere. However... with all of the great testing results...as well as superior support that Jacob, Jimmy, Brandon and the crew at Sundown Audio have shown me since I showed interest in the company, I grabbed my credit card and now have found myself with a pair of Sundown Audio sa15 15" subwoofers to play with. (Thank you Jacob)
I have to say... I honestly don't care too much about numbers from this build. It was meant to beat you to death with a small amount of power. The amplifier I'm currently running is a DDm3a rated at 2050 watts at 1 ohm. I have a stock battery under the hood and an upgraded alternator from Excessive Amperage. (Electrical upgrades are planned soon with some nice batts)...
Listening... the DD subs have a very serious pounding sensation to them that drills in deep and never quits from the beginning to the end of just about any song. The best number I ever scored with this setup was a 151.9dB in the kick NSPL hardcore style, and a 149.5dB sealed on the dash (legal style)... at the headrest (MECA style) a 150.0dB...
Now the Sundown sa15 subs landed in the truck. There was no need to re-adjust gains on the amplifier as the amplifier had been properly set with the wonderful SMD DD1 Distortion Detector. I hooked them up and went right to the meter. Fresh out of the box these subs were going to get a beating. I was impressed that they cranked out a crazy 151.4dB (.5dB away from the highest score with the DD subs) with the same power. Of course I realize the sa15" are getting very close to their rated power and the DD's rated at 1200 each are underpowered... still impressive. The numbers the Sundown put down are great numbers. but...please keep this in mind with a 16k on those 3500 DD 15" subs they cranked out over 156dB.
The Sundown subs immediately after metering went through a 45 minute music tri-athalon... Rock, Country, Rap, and even some Bass Mechanik, Psyph Morrison, DECAF, and some DJ Slow N Throw... I beat them to death... only one song I picked played below a 150dB and it was the "axel f" song from beverly hills cop and it still did a 149.4! REALLY!!! And the subs never even got warm! So at one point I got so excited that I cranked it up a bit too much past the clipping point (volume on deck) just to get some distortion to them and try to heat them up. Jacob, how you did it I will never know... but I knew when it was time to turn them down as I could smell a hint of Garlic. Yea Garlic... and I had two others confirm my scent diagnosis. hahaha... So I grabbed the meter with the subs still a bit hot from the hell I just gave them to see how they would still stack up when pushed to the edge of abuse for competition... SAME SCORE a 151.4dB! I have to say that for value, performance, and durability the Sundown sa15 15" subwoofers are the best sub I've ever punished. KUDOS to Sundown.
http://www.youtube.com/watch?v=zPHkZ8EQMNA
если достаточное количество людей попросят перевод текста, я постараюсь это осуществить...но в целом смысл понятен и с минимальным знанием англиского
Изменено пользователем Skillz
лучше ненадо переводить а то опять срачь будет:biggrin:
да пусть переведут мы же не в америке:wink:
152@30Hz
перевод через программу смысл ясен!
Оффтоп
Хотя некоторые могут считать, что это сравнительный тест ... это действительно не должно быть. У меня было два DD 3515 в Dodge в течение нескольких месяцев. Они серьезно большие подводные лодки. Я люблю их и не имеют планов по позволив им отправиться куда угодно. Тем не менее ... со всеми отличные результаты тестирования ... а также надежную поддержку, что Иаков, Джимми, Брэндон и экипажа на закате Аудио показали мне, как я проявлял интерес к компании, я схватил мою кредитную карту, а теперь нашли себя Пара Закат Аудио sa15 15 "сабвуфер, чтобы играть. (Спасибо Иакова)
Я должен сказать ... Честно говоря, я все равно слишком много о том номеров из этого строить. Он должен был бить тебя до смерти небольшое количество энергии. Усилитель я сейчас работает, DDm3a мощностью 2050 Вт на 1 Ом. У меня есть запас аккумулятора под капотом и обновлен генератор от чрезмерной силы тока. (Электрическая модернизации планируется в ближайшее время с некоторым хорошим сланцы) ...
Слушаю ... DD подводные лодки имеют очень серьезные удары ощущение им, что учения в глубоком и никогда не уходит от начала до конца почти любой песней. Лучший номер я когда-либо забил с этой установкой был 151.9dB в стиле хардкор удар NSPL и 149.5dB запечатаны на приборной панели (юридический стиль) ... на подголовник (MECA стиль) 150.0dB ...
Теперь Закат sa15 подводных лодок высадились в грузовик. Существовал не нужно перенастраивать прибыль от усилителя, усилитель был правильно настроен с прекрасным SMD детектор искажений DD1. Я подключил их и пошел прямо на метр. Свежее из коробки этих подводных лодок были собираюсь бить. Я был поражен, что они коленчатый из сумасшедшего 151.4dB (0,5 дБ от наибольшее количество очков с DD подводные лодки) с такой же мощности. Конечно, я понимаю, sa15 "становятся очень близко к их номинальной мощности и ДД мощностью 1200 каждого из них недостаточна ... все еще впечатляет. Номеров Закат положил в большом количестве. ... Но имейте это в виду, с 16k на тех 3500 DD 15 "сабвуферов они коленчатого над 156dB.
Закат подводных лодок сразу же после измерения прошла через 45 минут музыки три-athalon ... Рок, кантри, рэпа, и даже некоторые Bass Mechanik, Psyph Моррисон, кофе без кофеина, а некоторые DJ Slow N Бросьте ... Я бил их до смерти ... только одну песню я выбрал играли ниже 150 дБ, и это было "Axel F" песня из полицейского Беверли-Хиллз и она все-таки 149,4! РЕАЛЬНО! И подводные лодки никогда даже не согрелись! Так что в какой-то момент я так взволнован, что коленчатый это немного слишком много прошлого отсечения точки (объем на палубе) только, чтобы получить некоторые искажения к ним и попытаться тепла от них. Иакова, как вы сделали это, я никогда не узнаю ... но я знал, когда пришло время, чтобы превратить их вниз, как я почувствовал запах намека на чеснок. Да Чеснок ... и у меня было две другие подтверждают мой запах диагноза. хахаха ... Так что я схватил метр с подводных лодок еще немного горячей от черт возьми, я просто дал им понять, как они будут по-прежнему складывается при нажатии на край злоупотреблений на конкурс ... Одинаковым счетом 151.4dB! Я должен сказать, что по стоимости, производительности и долговечности Закат sa15 15 "Сабвуферы лучшим суб я когда-либо наказан. KUDOS до заката.
[СМИ]
Dj Mexx(Dj BassClub-а)
Продажа треков на заказ!
В личку!
muhahahaha ... он-лайн переводчики являются лучшими. Я думаю, я буду общаться на форуме через них. Особенно когда речь идет о подводных лодок или усилителей или их тестирования, надрать задницу
если в двух словах, то человек имеет 2 3515 и усилитель ДД м3а 2050вт в 1ом, соответственное питание, которое планируется улучшать, лучший результат что он снял с этой связки это 151,9 дб. Пообщавшись с тим сандаун аудио, решил прикупить пару са 15 и посмотреть на что они способны, ничего не переделывая поставил са15 в то же оформление от того же усилителя и снял всего на 0,5 дб меньше, и говорит что возможности сандаун близки к номинальным , а для ДД недостаточно, но всё же он впечатлён! после замеров погонял на музяке 45 минут , все песни на громкости 150дб и сабы даже не нагрелись, как это удалось якову он не понимает) подводя итог по стоимости, производительности и надежности он считает са 15 лучшими!
если где не так понял, поправте )
JVC NSX700+wh4.135+PPI.PM804NX+КГ-70+5.5k+Pride 2*bb-v2-15
Веселая история подводника, который кого-то бил до смерти на закате, от этого взволновался, и учуял запах чеснока =))))))))))
p.s. рассказ +1 в копилочку к Сандалям... Или как их там - "Закат Аудио" =)
двухлитровым должен быть пакет молока
Я собираюсь на PCA соревнования в воскресенье, могу сделать несколько видео грузовикa Rica, если кто-нибудь заинтересован :smile:
Короб.....короб пали со всех ракурсов......:biggrin:
Team Kicx !
