Skillz Опубликовано 30 сентября, 2012 Ссылка на тему Поделиться Опубликовано 30 сентября, 2012 (изменено) Выбирайте чо по-кайфу :hi: Fi Car Audio Ib3 18 d2 - 1шт 18" - 16000р - параметры Оффтоп IB3 Series: 12”, 15”, and 18” Single 2 and Single 4 Ohm Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals Extra heavy lead wire FEA optimized motor 3” diameter 2 or 4 layer coil Large single magnet Single progressive spider IB318 SINGLE 2 | SINGLE 4 Fs: 22.3 Hz | 22.5 Hz Re: 1.5 Ohms/coil | 2.8 Ohms/coil Qms: 3.33 | 3.41 Qes: ..81 | .77 Qts: .65 | .62 Mms: 272g | 270g Sd: 1210cm^2 | 1210cm^2 Vas: 381 l | 381 l Spl: 89.1dB 1W/1m | 89.4dB 1W/1m Bl: 8.43 N/A | 11.8 N/A Xmax: 30mm Rms: 550W @ 20Hz Sealed box: Infinite Baffle Only Ported box: N/A Sub OD: 18.500” Cut ID: 16.750” Mounting depth: 9.500” Displacement: 0.22cuft Ssd12 d2 - 3шт 12" - 15000р - параметры - Оффтоп SSD Series: 10”, 12”, 15”, and 18” Dual 1 and Dual 2 Ohm Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals Extra heavy lead wire FEA optimized motor 3” diameter 4 layer coil Single high grade magnet Triple progressive spiders Optional Heli-cool system SSD12 DUAL 1 | DUAL 2 Fs: 30.1 Hz | 30.1 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 7.65 | 7.65 Qes: .37 | .37 Qts: .36 | .36 Mms: 248g | 248g Cms: 0.11mm/N | 0.11mm/N Sd: 480cm^2 | 480cm^2 Vas: 36.5 l | 36.5 l Spl: 86.1dB 1W/1m | 86.1dB 1W/1m Bl: 13.1 N/A | 18.7 N/A Xmax: 20mm Rms: 1000W Sealed box: .7-1.2 cuft Ported box: 1.8-2.5 cuft @ 33Hz Sub OD: 12.500” Cut ID: 11.125” Mounting depth: 6.500” Displacement: 0.14cuft Ssd15 d2 red - 1шт 15" - 16000р - параметры - Оффтоп SSD Series: 10”, 12”, 15”, and 18” Dual 1 and Dual 2 Ohm Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals Extra heavy lead wire FEA optimized motor 3” diameter 4 layer coil Single high grade magnet Triple progressive spiders Optional Heli-cool system SSD15 DUAL 1 | DUAL 2 Fs: 29.6 Hz | 29.6 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 8.73 | 8.73 Qes: .43 | .43 Qts: .41 | .41 Mms: 288g | 288g Cms: 0.10mm/N | 0.10mm/N Sd: 810cm^2 | 810cm^2 Vas: 93.0 l | 93.0 l Spl: 89.3dB 1W/1m | 89.3dB 1W/1m Bl: 13.1 N/A | 18.7 N/A Xmax: 20mm Rms: 1000W Sealed box: 1.5-2.5 cuft Ported box: 3-4 cuft @ 33Hz Sub OD: 15.625” Cut ID: 14.125” Mounting depth: 8.000” Displacement: 0.17cuft Ssd18 d1 - 1шт 18" - 18500р - параметры - Оффтоп SSD Series: 10”, 12”, 15”, and 18” Dual 1 and Dual 2 Ohm Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals Extra heavy lead wire FEA optimized motor 3” diameter 4 layer coil Single high grade magnet Triple progressive spiders Optional Heli-cool system SSD18 DUAL 1 | DUAL 2 Fs: 27.6 Hz | 27.6 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 9.56 | 9.56 Qes: .47 | .47 Qts: .45 | .45 Mms:338g | 338g Cms: 0.098mm/N | 0.098mm/N Sd: 1210cm^2 | 1210cm^2 Vas: 201.4 l | 201.4 l Spl: 91.4dB 1W/1m | 91.4dB 1W/1m Bl: 13.1 N/A | 18.7 N/A Xmax: 20mm Rms: 1000W Sealed box: 3.5-5 cuft Ported box: 6-10 cuft @ 33Hz Sub OD: 18.500” Cut ID: 16.750” Mounting depth: 9.500” Displacement: 0.22cuft Q10 d2 - 1шт 10" - 18000р - параметры - Оффтоп Dual 1 and Dual 2 Ohm Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals Extra heavy lead wire FEA optimized motor 3" diameter 4 layer coil Single high grade magnet Quad progressive spiders High or low Qts motors Optional Heli-cool system And many other custom options Q10 DUAL 1 | DUAL 2 Fs: 34.1 Hz | 34.0 Hz Re: 0.70 Ohms/coil | 1.4 Ohms/coil Qms: 7.31 | 7.38 Qes: .37 | .37 Qts: .36 | .36 Mms: 230g | 2235g Cms: .88mm/N | .88mm/N Sd: 310cm^2 | 310cm^2 Vas: 11.8 l | 11.8 l Spl: 83.3dB 1W/1m | 83.2dB 1W/1m Bl: 13.9 N/A | 19.6 N/A Xmax: 28mm Rms: 1500W Sealed box: .2-.5 cuft HQTS Ported box: .5-1.2 cuft @ 28-33Hz Sub OD: 11.000” Cut ID: 9.250” Mounting depth: 6.500” Displacement: 0.12cuft Q15 d2 blue - 1шт 15" - 20000р - параметры - Оффтоп Dual 1 and Dual 2 Ohm Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals Extra heavy lead wire FEA optimized motor 3" diameter 4 layer coil Single high grade magnet Quad progressive spiders High or low Qts motors Optional Heli-cool system And many other custom options Q15 DUAL 1 | DUAL 2 Fs: 32.4 Hz | 32.1 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 8.52 | 8.61 Qes: .43 | .44 Qts: .41 | .42 Mms: 293g | 299g Cms: 0.82mm/N | 0.82mm/N Sd: 810cm^2 | 810cm^2 Vas: 75.6 l | 75.6 l Spl: 89.6dB 1W/1m | 89.4dB 1W/1m Bl: 13.9 N/A | 19.65 N/A Xmax: 28mm Rms: 1500W Sealed box: 2-2.6 cuft Ported box: 2.8-4 cuft @ 28-33Hz Sub OD: 15.625” Cut ID: 14.125” Mounting depth: 8.500” Displacement: 0.19cuft BTL n3 12 d1 - 1шт BTL n3 12 d2 - 2шт 12" - 48000р - параметры - Оффтоп BTL Series: 12”, 15”, and 18” Dual 1 and Dual 2 Ohm (custom options available) Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals 16 integrated leads FEA optimized motor High Flux density design 3” diameter 8 layer coil (High Xmax coil option) Triple Neodymium high flux magnets 5-7 progressive spiders packs Optional Heli-cool system Tri-flow integrated heatsink And many other custom options N312 DUAL 1 | DUAL 2 Fs: 56.3 Hz | 55.3 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 7.45 | 7.69 Qes: .26 | .25 Qts: .25 | .24 Mms: 214g | 222g Sd: 480cm^2 | 480cm^2 Vas: 12.1 l | 12.1 l Spl: 91.1dB 1W/1m | 90.8dB 1W/1m Bl: 20.2 N/A | 28.8 N/A Xmax: 28mm | 28mm Rms: 3000W | 3000W Sealed box: N/A cuft | N/A cuft Ported box: 1.5-2.5cuft | 1.5-2.5cuft Sub OD: 12.500” | 12.500” Cut ID: 11.125” | 11.125” Mounting depth: 7.250” | 7.250” Displacement: 0.18cuft | 0.18cuft BTL n3 15 d1 - 3шт 15" - 49000р - параметры - Оффтоп BTL Series: 12”, 15”, and 18” Dual 1 and Dual 2 Ohm (custom options available) Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals 16 integrated leads FEA optimized motor High Flux density design 3” diameter 8 layer coil (High Xmax coil option) Triple Neodymium high flux magnets 5-7 progressive spiders packs Optional Heli-cool system Tri-flow integrated heatsink And many other custom options N315 DUAL 1 | DUAL 2 Fs: 54.5 Hz | 54.4 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 9.19 | 9.28 Qes: .32 | .32 Qts: .31 | .31 Mms: 274g | 280g Sd: 810cm^2 | 810cm^2 Vas: 28.95 l | 28.95 l Spl: 93.4dB 1W/1m | 93.3dB 1W/1m Bl: 20.2 N/A | 28.8 N/A Xmax: 28mm | 28mm Rms: 3000W | 3000W Sealed box: N/A cuft | N/A cuft Ported box: 2.5-5cuft | 2.5-5cuft Sub OD: 15.625” | 15.625” Cut ID: 14.125” | 14.125” Mounting depth: 8.750” | 8.750” Displacement: 0.21cuft | 0.21cuft BTL n3 18 d1 - 2шт BTL n3 18 d2 - 2шт 18" - 52000р - параметры - Оффтоп BTL Series: 12”, 15”, and 18” Dual 1 and Dual 2 Ohm (custom options available) Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals 16 integrated leads FEA optimized motor High Flux density design 3” diameter 8 layer coil (High Xmax coil option) Triple Neodymium high flux magnets 5-7 progressive spiders packs Optional Heli-cool system Tri-flow integrated heatsink And many other custom options N318 DUAL 1 | DUAL 2 Fs: 51.1 Hz | 50.4 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 10.1 | 10.26 Qes: .36 | .35 Qts: .35 | .34 Mms: 320g | 329g Sd: 1210cm^2 | 1210cm^2 Vas: 62.1 l | 62.1 l Spl: 95.3dB 1W/1m | 95.4dB 1W/1m Bl: 20.2 N/A | 28.8 N/A Xmax: 28mm | 28mm Rms: 3000W | 3000W Sealed box: N/A cuft | N/A cuft Ported box: 4-10cuft | 4-10cuft Sub OD: 18.500” | 18.500” Cut ID: 16.750” | 16.750” Mounting depth: 10.250” | 10.250” Displacement: 0.26cuft | 0.26cuft Sp4 15 d1 - 3шт Sp4 15 d2 - 4шт 15" - 37500р - параметры - Оффтоп SP4 Series: Currently in 15” and 18” Dual 1 and Dual 2 Ohm (custom options available) Extra heavy aluminum basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals 144 tinsel count leads FEA optimized motor High Flux density design 4” diameter 4 layer coil (Flatwind standard) Double stack magnets Five progressive 10" spiders Optional Heli-cool systerm Machined in house at Fi And many other custom options SP415 DUAL 1 | DUAL 2 Fs: 27.6 Hz | 27.9 Hz Re: 0.65 Ohms/coil | 1.27 Ohms/coil Qms: 6.56 | 6.45 Qes: .52 | .52 Qts: .48 | .48 Mms: 434g | 424g Cms: 0.77mm/N | 0.77mm/N Sd: 810cm^2 | 810cm^2 Vas: 70.4 l | 70.4 l Spl: 86.4dB 1W/1m | 86.5dB 1W/1m Bl: 13.7 N/A | 19.1 N/A Xmax: 33mm | 33mm Rms: 2500W | 2500W Sealed box: 2-3.5cuft | 2-3.5 cuft Ported box: 3-5cuft | 3-5cuft Sub OD: 15.625” | 15.625” Cut ID: 14.125” | 14.125” Mounting depth: 11.250” | 11.250” Displacement: 0.21cuft | 0.21cuft Sp4 18 d2 - 2шт 18" - 39000р - параметры - Оффтоп SP4 Series: Currently in 15” and 18” Dual 1 and Dual 2 Ohm (custom options available) Extra heavy aluminum basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals 144 tinsel count leads FEA optimized motor High Flux density design 4” diameter 4 layer coil (Flatwind standard) Double stack magnets Five progressive 10" spiders Optional Heli-cool systerm Machined in house at Fi And many other custom options SP418 DUAL 1 | DUAL 2 Fs: 24.7 Hz | 24.9 Hz Re: 0.65 Ohms/coil | 1.27 Ohms/coil Qms: 7.45 | 7.38 Qes: .60 | .59 Qts: .55 | .55 Mms: 555g | 544g Cms: 0.74mm/N | 0.74mm/N Sd: 1210cm^2 | 1210cm^2 Vas: 153.7 l | 153.7 l Spl: 87.8dB 1W/1m | 87.9dB 1W/1m Bl: 13.7 N/A | 19.1 N/A Xmax: 33mm | 33mm Rms: 2500W | 2500W Sealed box: 4-6 cuft | 4-6 cuft Ported box: 6-8cuft | 6-8cuft Sub OD: 18.500” | 18.500” Cut ID: 16.750” | 16.750” Mounting depth:11.750” | 11.750” Displacement: 0.26cuft | 0.26cuft Ascendant Audio Arsenal 12 d4 - 5шт Arsenal 15 d4 - 1щт Chaos 10d2 - 1шт Havoc12 d1 - 1шт Havoc12 d2 - 1шт Havoc 15 d1 - 3шт Havoc 18 d1 - 1шт Havoc 18 d2 - 2шт Mayhem 12 d1 - 3шт Mayhem15 d2 - 2шт Mayhem 18 d2 - 2шт Mayhem 18 d1 - 1шт Изменено 3 октября, 2012 пользователем Skillz Личка переполнена - пишите Вконтакте vk.com/gotskillz Ссылка на комментарий
Parseg89 Опубликовано 30 сентября, 2012 Ссылка на пост Ссылка на тему Поделиться Опубликовано 30 сентября, 2012 BTL n3 15 d1, Sp4 15 d1 можно цену узнать? 3-Way DD VO+SS2+SS4,M4a+9518,Shok+Mechman 270Ah =::hair:: Ссылка на комментарий
413 Опубликовано 30 сентября, 2012 Ссылка на пост Ссылка на тему Поделиться Опубликовано 30 сентября, 2012 да, неплохо бы было ценник возле каждой позиции написать, чтобы люди не лазали из темы в тему :blush: Ссылка на комментарий
_Alexsey_ Опубликовано 30 сентября, 2012 Ссылка на пост Ссылка на тему Поделиться Опубликовано 30 сентября, 2012 \ сказал: BTL n3 15 d1' date=' Sp4 15 d1 можно цену узнать?[/quote'] вот скорее всего http://www.bassclub.ru/forum/showthread.php?t=33834 Ссылка на комментарий
Skillz Опубликовано 1 октября, 2012 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 1 октября, 2012 Все цены - розница как указанно в соответствующих темах. Но есть спец предложениях На сабы Ascendant Audio 2 штуки - AA Havoc 18" - 49000р 2 штуки - AA Havoc d1 15" - 44000р 2 штук АА Aresenal 15d4 + Sundown Audio SAZ1500v3 - 45000р Только до выходных Личка переполнена - пишите Вконтакте vk.com/gotskillz Ссылка на комментарий
Skillz Опубликовано 1 октября, 2012 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 1 октября, 2012 При покупке Fi BTL n3 - ценный подарок! Личка переполнена - пишите Вконтакте vk.com/gotskillz Ссылка на комментарий
Skillz Опубликовано 4 октября, 2012 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 4 октября, 2012 Подправил с ценами и описанием. Если вечером не сдамся, то и по АА тоже сделаю Личка переполнена - пишите Вконтакте vk.com/gotskillz Ссылка на комментарий
413 Опубликовано 12 ноября, 2012 Ссылка на пост Ссылка на тему Поделиться Опубликовано 12 ноября, 2012 по наличию инфа акутальна? Ссылка на комментарий
Skillz Опубликовано 12 ноября, 2012 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 12 ноября, 2012 413 сказал: по наличию инфа акутальна? На 90% да. Лучше спросить конкретно что интересует, я уточню Личка переполнена - пишите Вконтакте vk.com/gotskillz Ссылка на комментарий
413 Опубликовано 12 ноября, 2012 Ссылка на пост Ссылка на тему Поделиться Опубликовано 12 ноября, 2012 Q10 d2 -1 шт Ссылка на комментарий
Skillz Опубликовано 12 ноября, 2012 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 12 ноября, 2012 413 сказал: Q10 d2 -1 шт Есть такой :good: Личка переполнена - пишите Вконтакте vk.com/gotskillz Ссылка на комментарий
adidas Опубликовано 12 декабря, 2012 Ссылка на пост Ссылка на тему Поделиться Опубликовано 12 декабря, 2012 обновить бы инфу по наличию Ссылка на комментарий
legionn Опубликовано 12 декабря, 2012 Ссылка на пост Ссылка на тему Поделиться Опубликовано 12 декабря, 2012 подарите два майхема 12 2+2ом на новый год за недорого:) Ссылка на комментарий
Prado Опубликовано 12 декабря, 2012 Ссылка на пост Ссылка на тему Поделиться Опубликовано 12 декабря, 2012 Даешь Майхэмов Нижнему!:lol: Gorky Style Ссылка на комментарий
Skillz Опубликовано 12 декабря, 2012 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 12 декабря, 2012 две 12хи майхем есть за хорошую цену - д1 Личка переполнена - пишите Вконтакте vk.com/gotskillz Ссылка на комментарий
