Черная пятница в самом разгаре! Fi Car Audio в наличии!
Skillz
Тут значит мы тоже хотим немного склад разгрузить, особенно от штучных сабов.
все в наличии, отправка автотрейдингом в течении 48 часов после получения оплаты
Fi IB3 18" d2 (это саб для бесконечного экрана)
18" - 11000р - параметры Оффтоп
IB3 Series: 12”, 15”, and 18”
Single 2 and Single 4 Ohm
Cast basket
Wrap around gasket
Kraft pulp fiber reinforced cone
Single layer wide foam surround
Push terminals
Extra heavy lead wire
FEA optimized motor
3” diameter 2 or 4 layer coil
Large single magnet
Single progressive spider
IB318
SINGLE 2 | SINGLE 4
Fs: 22.3 Hz | 22.5 Hz
Re: 1.5 Ohms/coil | 2.8 Ohms/coil
Qms: 3.33 | 3.41
Qes: ..81 | .77
Qts: .65 | .62
Mms: 272g | 270g
Sd: 1210cm^2 | 1210cm^2
Vas: 381 l | 381 l
Spl: 89.1dB 1W/1m | 89.4dB 1W/1m
Bl: 8.43 N/A | 11.8 N/A
Xmax: 30mm
Rms: 550W @ 20Hz
Sealed box: Infinite Baffle Only
Ported box: N/A
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 9.500”
Displacement: 0.22cuft
Fi SSD 18 d1
18" - 14500р - параметры - Оффтоп
SSD Series: 10”, 12”, 15”, and 18”
Dual 1 and Dual 2 Ohm
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
3” diameter 4 layer coil
Single high grade magnet
Triple progressive spiders
Optional Heli-cool system
SSD18
DUAL 1 | DUAL 2
Fs: 27.6 Hz | 27.6 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 9.56 | 9.56
Qes: .47 | .47
Qts: .45 | .45
Mms:338g | 338g
Cms: 0.098mm/N | 0.098mm/N
Vas: 201.4 l | 201.4 l
Spl: 91.4dB 1W/1m | 91.4dB 1W/1m
Bl: 13.1 N/A | 18.7 N/A
Xmax: 20mm
Rms: 1000W
Sealed box: 3.5-5 cuft
Ported box: 6-10 cuft @ 33Hz
Sub OD: 18.500”
Cut ID: 16.750”
Fi Q18 d2
18" - 17000р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
3" diameter 4 layer coil
Quad progressive spiders
High or low Qts motors
And many other custom options
Q18
DUAL 1 | DUAL 2
Fs: 32.4 Hz | 32.1 Hz
Qms: 9.31 | 9.37
Qes: .48 | .48
Qts: .46 | .46
Mms: 341g | 347g
Cms: 0.73mm/N | 0.73mm/N
Vas: 149.7 l | 149.7 l
Spl: 92.0dB 1W/1m | 91.9dB 1W/1m
Bl: 13.9 N/A | 19.65 N/A
Xmax: 28mm
Rms: 1500W
Sealed box: 4-8 cuft
Ported box: 6-10 cuft @ 28Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 10.000”
Displacement: 0.24cuft
Fi BL18 d2
18" - 21000р - параметры - Оффтоп
BL Series: 10”, 12”, 15”, and 18”
Dual 1 and Dual 2 Ohm (custom options available)
Cast basket
Wrap around gasket
Push terminals
16 integrated leads
FEA optimized motor
High Flux density design
3” diameter 4 layer coil (Flatwind option)
Double stack magnets
Five progressive spiders
Optional Heli-cool systerm
Machined in house at Fi
BL18
DUAL 1 | DUAL 2
Fs: 33.2 Hz | 33.2 Hz
Qms: 5.82 | 5.82
Qes: .32 | .32
Qts: .30 | .30
Mms: 302g | 302g
Cms: 0.88mm/N | 0.88mm/N
Vas: 181.0 l | 181.0 l
Spl: 94.1dB 1W/1m | 94.1dB 1W/1m
Bl: 16.6 N/A | 22.7 N/A
Xmax: 18mm | 18mm
Rms: 1500W * | 1500W *
Sealed box: N/A cuft | N/A cuft
Ported box: 5-8cuft | 5-8cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth: 9.750” * | 9.750” *
Displacement: 0.26cuft * | 0.26cuft *
Fi BTL N3 18" d1
18" - 39000р - параметры - Оффтоп
BTL Series: 12”, 15”, and 18”
Cast basket
Wrap around gasket
Push terminals
16 integrated leads
FEA optimized motor
3” diameter 8 layer coil (High Xmax coil option)
Triple Neodymium high flux magnets
5-7 progressive spiders packs
Tri-flow integrated heatsink
N318
DUAL 1 | DUAL 2
Fs: 51.1 Hz | 50.4 Hz
Qms: 10.1 | 10.26
Qes: .36 | .35
Qts: .35 | .34
Mms: 320g | 329g
Vas: 62.1 l | 62.1 l
Spl: 95.3dB 1W/1m | 95.4dB 1W/1m
Bl: 20.2 N/A | 28.8 N/A
Xmax: 28mm | 28mm
Rms: 3000W | 3000W
Ported box: 4-10cuft | 4-10cuft
Mounting depth: 10.250” | 10.250”
Displacement: 0.26cuft | 0.26cuft
Fi SP4 18" d1
18" - 32000р - параметры - Оффтоп
SP4 Series: Currently in 15” and 18”
Extra heavy aluminum basket
Wrap around gasket
Push terminals
144 tinsel count leads
FEA optimized motor
4” diameter 4 layer coil (Flatwind standard)
Five progressive 10" spiders
SP418
DUAL 1 | DUAL 2
Fs: 24.7 Hz | 24.9 Hz
Re: 0.65 Ohms/coil | 1.27 Ohms/coil
Qms: 7.45 | 7.38
Qes: .60 | .59
Qts: .55 | .55
Mms: 555g | 544g
Cms: 0.74mm/N | 0.74mm/N
Vas: 153.7 l | 153.7 l
Spl: 87.8dB 1W/1m | 87.9dB 1W/1m
Bl: 13.7 N/A | 19.1 N/A
Xmax: 33mm | 33mm
Rms: 2500W | 2500W
Sealed box: 4-6 cuft | 4-6 cuft
Ported box: 6-8cuft | 6-8cuft
Mounting depth:11.750” | 11.750”
Внимание! все сабы по одной штуке! все опции включенs - fully loaded. для просмотра параметров жмем на offtopic
18ху q-серии за 17000 никто не видит что-ли? :lol:
все еще в шоке...:shok: от цен:good: жаль с финансами туго, прихватил бы я сабик по сладкой цене)))
BLACK BASS, следим за лексиконом ...
Титанат от БасКлуба
Упакуйся по полной - ЗАКАЗАТЬ
EddyFierce, редактируем подпись ...
Титанат от БасКлуба
Хотя на складе вроде еще нашлась 1:drinks:
Точно?
:good:
Денис 762, уже нет:wink:
2015 - SS1-2 170.6db мировой рекорд (Seat Marbella)
2016 - 2018 - топовый повседневный SS5+ (163.0) #проект11
2019 - ...
Точно?
есть 2*18 сп4. 2+2 Ома новые. доставались только из коробки. поставить не успели-холода.Весной приору на продажу выставляют,поэтому сабы не очень уже и нужны. Личка
TEAM R15
Уверенно продолжаем этот ахтунг до конца недели.
Свежее дополнение - два Fi BTL N3 12" d2 fully loaded (все опции) за 66000р из наличия
