Audi A4 Avant - 2 Fi SP4 15" - SPL Dynamics D6 - Dual Alts - Boot Install
AudiBasser
Hi everybody.
I apologise for my lack of language skills, Russian isn't something I'm fluent in but I love some of the cars you have on here so decided to sign up!
Here is my little install.
I have a 2004 Audi A4 Avant 1.9TDI Sport (6 speed manual, pd130 avf engine)
I have had many installs in this car, starting off with 2 Fi BTL 15" subs with an Atomic 5kwrms amp
Videos of this set up are here
Then I went to 1 15" BTL on a few different amps, started off with Sundown SAZ1500D, then Rockford Fosgate T20001BD and then a Ground Zero 1.2500DXii
Videos here
..then now I have 2 Fi SP4 15" subwoofers, ran off a SPL Dynamics D6 amplifier.
A few early videos here
These videos are when the subs were getting very little power.
I will go through all the stages of my build, including all the equipment I use, the fitting of the dual alts and the actual subwoofer box itself. :cool1:
  • Ответов 31
The car itself
Headunit - Alpine 9887R with full speed iPod connection
Front speakers are Ground Zero GZUZ165SQ
Amping these is a Crystal CAM200.2
Rear speakers are standard.
The subs, fully loaded Fi SP4 15" Dual 1s.
Powering the subs we have the SPL Dynamics D6 which puts out around 6kwrms @ 1 ohm
A few other bits
DD1
SPL Lab LCD Meter
Suspension and brake upgrades
Изменено пользователем AudiBasser
First thing - power supply!
On these VAG engines there is an alternator you can fit from a Renault van, it is rated at 210a but in clamp tests people get 260-300a with them using external regulators.
First 210a alternator replacing standard alternator
With this I had 1 run of Knukonceptz 0g OFC positive going to the back and using chassis grounds.
I used this set up for my previous installs. When planning the SP4 install I knew I needed to make it stronger ;)
3 XS Power D3400 batteries (1 for standard replacement, 2 to put in the back)
2 more runs of Knukonceptz 0g OFC, one positive, one for negative from front to back
Lots of fuses!
Then I wanted to put a second alternator on, so I took it 200 miles to a company in London, they removed my air con pump and fitted a second 210a alternator. MY air con system was already faulty, the radiator had broken so wasn't working.
Removing air con pump
Getting the bracket ready
Test fitting
Finally fitted using a Goodyear Gator Back belt
Both alternators are connected to a single external regulator.
Unfortunately I had some minor problems, a few weeks ago the alternator managed to break off from the bracket so I had to go down again and have it fixed.
On the way there the second alternator broke off on the motorway while driving at 70mph!
The company replaced this FREE OF CHARGE!
New bracket test fitted
Everything reconnected
So far I have not had any more problems with this.
2 XS Power D3400 batteries in the boot
3 runs of 0g from front to back - 2 + 1 -
Fitting suspension and brakes
When doing suspension the installer found the front passenger drop link was very worn
Old suspension and brakes
The subwoofer enclosure.
This was made out double layered 18mm plywood, the subs face up and port fires back. The port itself is variable, so we can make new ports and change them when we want.
Test fit
Making the ports - we have 2 ports at the moment - 27hz and 35hz
27hz port
35hz port
Box painted
Test fit with 27hz port
Now with subs...
:biggrin:
  Matbeu сказал:
Glad to see you on our forum, great instal, need more pictures)
It is an honour to be on here. I hope you are all liking my install. I do feel a bit embarassed that I can't engage with you all properly as I can't speak Russian but do thank you all for being patient and accepting me using English.
More pictures are coming up my friend :smile:
Once I had my car back with install the subs were wired to a high load, so they got very little power but they were still very impressive. Here are some low powered scores when the subs were stiff.
I then had the subs rewired and WOW it was amazing.
My problem now was that when the volume was turned up the CD player skipped. The only score I could get is 20hz
I got this up to 147.4 with a small tweak.
More problems...
I was burping and the Crystal amp let out some smoke, ooops!
Power FET blown! ::focus::
New equipment time
Upgrading from 2x125wmrs@4ohm to 4x125@4ohm :nyam2:
  lildeem сказал:
u understand russian, but cant speak?
Google translate helps me understand :lol:
Maybe one day I will be able to speak Russian, I certainly want to visit Russia sometime soon...
I think one of the reasons my Crystal amp broke was because it was mounted on the subwoofer enclosure, so I am having it relocated
Hmm which way
Removing the seats so the installer can have them to work on
Nice wiring
The seat is still in progress, I will post completed pics of this soon.
With all this bass I had a lot of ratles and vibrations. I had very little sound deadening on the car.
I ordered some Silent Coat Extra deadening - 25sqft, 4mm thick
I will be applying the deadening soon - expect some pics
The boot lid still made lots of rattles, so I took off the trim. My installer is making this very strong, fibre glassing it, smoothing it off and painting it.
Haha, so the community grows...glad to have you here man, I think I remember seeing this build over on SMD
And yes, moving the 4ch off of the enclosure is a good idea, first thing I though when I saw that first pic of the amp mounted there - it's not gonna last long...... NAND then I read you next post about it blowing
  rea|EVGEN сказал:
Well done! Keep moving...
Thank you, plenty more to come!
  Skillz сказал:
:drinks:
Thanks, I also love what you guys have been doing, I follow your threads on CACO quite closely!
As for the amp, it's lasted me a long time and will be a cheap fix anyway, after the new year I will be having it repaired and selling it. When finishing the enclosure it was hard to find space for the amp anywhere else, as you can see previously with my BTLs I had the subs and port firing up, so had space either side of the box for amp mounting, with the new box I'm much more limited.
