Добавьте
Victor
Добрый день, вечер и ночи всем. Опять затрагиваю тему страшнейших моноблоков для автомобилей. Прошу вас внести коррректировки или добавления в мой список. Нижняя граница 2500 ватт. За ранее всем благодарен!
Ground Zero Amplifier - GZPA 2_20000SPL 16.600 RMS(THD 1%) @ 2 Ohm 22.000(THD 10% 18V) @ 2 Ohm
Rockford Fosgate T15kW 2 X 7.500 RMS(THD 1%) @ 1 Ohm (2006)
Earthquake PHD20000W/D1 12.000 RMS(THD 1%) @ 2 Ohm max 20.000 @ 2 Ohm (2006)
Phoenix Gold Titanium Elite MPH10K 4 X 2.500 RMS(THD 1%) @ 2 Ohms (under developement)
Hifonics XXV-Maxximus 10.000 RMS(THD 1%) @ 2 Ohm 2007! (15.200 RMS(THD 1%) 18V)
Hifonics XX Maxximus 10.000 RMS(THD 1 %) @ 2 Ohm
Kicker Warhorse WX10000.1 10.000 RMS(THD 1%) @ 2 Ohm
SoundStream XXX-10000D 8.500 RMS(THD 1%) @ 1 Ohm 10.000(THD 10%) @ 1 Ohm (2006)
Ground Zero Amplifier - GZPA 1_10000SPL 8.300 RMS(THD 1%) @ 1 Ohm 9.500(THD 10%) @ 1 Ohm
JBL CROWN A6000GTI 8.100 RMS(THD 1%) @ 4 Ohms max 10.000
Hifonics XXV-Sampson 8.000 RMS(THD 1%) @ 1 Ohms (New for 2007!) (10.200 RMS(THD 1%) 18V)
SoundStream XXX-6500D 6.500 RMS(THD 1%) @ 1 Ohm
Cadence ZRS-9000D 6.000 RMS(THD 1%) @ 1 Ohm (New for 2007!) 9.000(THD 10% 18V) @ 1 Ohm
Earthquake PHD10000W/D1 6.000 RMS(THD 1%) @ 2 Ohm (2006) max 10.000 @ 2 Ohm
Earthquake PHD10000W 6.000 RMS(THD 1%) @ 2 Ohms max 10.000 @ 2 Ohm
Ground Zero Amplifier - GZPA 1_8000D 6.000 RMS(THD 1%) @ 2 Ohm
DD-Z2 6.000 RMS(THD 1%) @ 1 Ohm
Ground Zero Amplifier - GZPA 1_6500SPL 5.800 RMS(THD 1%), 6.500(THD 10%) @ 1 Ohm 8.000(THD 10% 18V) @ 1 Ohm
Cadence Daytona DCA5000 5.000 RMS(THD 1%) @ 1 Ohm
Hifonics XXV-Goliath 5.000 RMS(THD 1%) @ 1 Ohm New for 2007! (7.600 RMS(THD 1%) @ 1 Ohm 18V)
Hifonics XX Goliath 5.000 RMS(THD 1%) @ 1 Ohm
AudioBahn A5000SPL 5.000 RMS(THD 1%) @ 1 Ohm
MA Audio HK10KD 5.000 RMS(THD 1%) @ 1 Ohm
DD-Z1a 5.000 RMS(THD 1%) @ 1 Ohm max 7.000
Ground Zero Amplifier - GZPA 1_6000D 4.500 RMS(THD 1%) @ 2 Ohm
MA Audio HK-802SX 4400 RMS(THD 1%) @ 1 Ohm
Power Acoustik SL-5500D 4.200 RMS(THD 1%) @ 1 Ohm(2006)
Zapco C2K4KW 2 X 2.000 RMS(THD 1%) @ 2 Ohm
AutoTek MM4000.1D 4.000 RMS(THD 1%) @ 2 Ohm
Crossfire VR4000D 4.000 RMS(THD 1%) @ 2 Ohm
Hifonics XXV-Cyclops 4.000 RMS(THD 1%) @ 1 Ohm New for 2007! (6.300RMS(THD 1%) 18V)
Hifonics XX-Cyclops 4.000 RMS(THD 1 %) @ 1 Ohm (2006)
Hifonics XX-Thor 4.000 RMS(THD 1%) @ 1 Ohm
Rockford Fosgate T4001BD 4.000 RMS(THD 1 %) @ 1 Ohm (2006)
Celestra DA6K 4.000 RMS(THD 1%) @ 1 Ohm 6.000(THD 1% 18V) @ 1 Ohm
MMats HD4000.1 4.000 RMS(THD 1%) @ 1 Ohm
Memphis Mojo MCD4KW 4.000 RMS(THD 1%) @ 1 Ohm
Memphis M3 Mojo 4.000 RMS(THD 1%) @ 1 Ohm
Clif Designs CDX-20A 3.600 RMS(THD 1%) @ 2 Ohm
MA Audio HK-602SX 3.600 RMS(THD 1%) @ 1 Ohm
MA Audio HK-4000D 3.600 RMS(THD 1%) @ 1 Ohm 4.000(THD 10%) @ 1 Ohm
Visonik V4000XD 3.500 RMS(THD 1%) @ 2 Ohm
SoundStream Picasso PCA-3500D 3.500 RMS(THD 1%) @ 1 Ohm
Hifonics XXV-Colossus 3.200 RMS(THD 1%) @ 2 Ohm New for 2007! (3800RMS(THD 1%) 16V)
Hifonics XX Colossus-2 3.200 RMS(THD 1%) @ 2 Ohm
Power Acoustik OV1-5500D 3.200 RMS(THD 1%) @ 1 Ohm New for 2007!
Power Acoustik PS1-5500D 3.200 RMS(THD 1%) @ 1 Ohm New for 2007!
Kole Audio KX1-5500D 3.200 RMS(THD 1%) @ 1 Ohm New for 2007!
SPL Audio FX1-5500D 3.200 RMS(THD 1%) @ 1 Ohm New for 2007!
JBL A3000GTI 3.129 RMS(THD 1%) @ 4 Ohm
AutoTek MM3000.1D 3.000 RMS(THD 1%) @ 2 Ohm New for 2007!
AutoTek MX-3000.1 3.000 RMS(THD 1%) @ 2 Ohm (Class X)
Earthquake PH5000W/D1 3.000 RMS(THD 1%) @ 2 Ohm
Earthquake PHD5000W 3.000 RMS(THD 1%) @ 2 Ohm
Boss Audio PD-4000 2 X 1.500 RMS(THD 1%) @ 1 Ohm
Hifonics XXV-Thor 3.000 RMS(THD 1%) @ 1 Ohm New for 2007! (5000RMS(THD 1%) 18V)
Hifonics XX-Thor 3.000 RMS(THD 1%) @ 1 Ohm
Rockford Fosgate T30001BD 3.000 RMS(THD 1%) @ 1 Ohm
US Amps AX-3000DE 3.000 RMS(THD 1%) @ 1 Ohm
MTX-X3000D 3.000 RMS(THD 1%) @ 1 Ohm
MTX-TA92001 3.000 RMS(THD 1%) @ 1 Ohm
PPI Precision Power D3000/1 3.000 RMS(THD 1%) @ 1 Ohm
Earthquake PHD3 3000 RMS(THD 1%) @ 1 Ohm
MMats D3500.1/3500.05 2.700 RMS(THD 1%) @ 1 or 0.5 Ohms 3.500(THD 10%) @ 1 or 0.5 Ohm
SPL DK-3400D 2.600 RMS(THD 1%) @ 1 Ohm 3.400(THD 10%)
Orion HCCA-D5000 2.500 RMS(THD 1%) @ 1 Ohm max 5.000 (2006)
Многое из списка снято с производства.
Ну и можно расставить их по реальной мощности, картинка иная будет. Завтра если время будет, сделаю :)
И еще среднюю цену на усилки из списка укажите.:good:
Team Tyumen-Чемпионы РФ
RASKA - 2013,14
AMT спл шоу - 2014
а где Z2?
Надо в алфавитном порядке спсиок сделать:biggrin:
RASKA - 2013,14
AMT спл шоу - 2014
Да я ломал глаза, ломал, так и не увидел... а поиск зло!
DiEU ET MON DROiT / The only thing necessary for the triumph of evil is for good men to do nothing.
DD Z2-HV 12.000 RMS(THD 1%) @ 1 Ohm @ 18V
DD-Z2-LV 10.000 RMS(THD 1%) @ 1 Ohm @ 16V
Stetsom 7K2D и 10kD примерно равны ДДшым усям, семерка чуть слабее LV, 10-ка чуть сильнее HV.
SoundStream XXX-10000D 6.500 RMS(THD 1%) @ 1 Ohm 10.000(THD 10%) @ 1 Ohm (2006)
Rockford Fosgate T40001BD 4.500 RMS(THD 1 %) @ 1 Ohm (2006)
SoundStream XXX-6500D 4.300 RMS(THD 1%) @ 1 Ohm
DD M3 2800 RMS @ 1Ohm.
Вот примерно так. остальные из списка либо сняты с производства, либо не дотягивают до 2500Вт. Кроме Хайфониксов, которых ооооочень много всяких, всех не перечислишь:sarcastic: Мощность старался написать реальную, а не заявку.
Мог кого-то забыть конечно........
Smoke, Еще про Ланзар ОПТИ 4000 забыли
Ни в первоначальном, ни в твоем списке не нашел.
Или его тоже сняли с производства?
http://ampguts.realmofexcursion.com/Lanzar_OPTI_4000D/
Изменено пользователем Русик
RASKA - 2013,14
AMT спл шоу - 2014
Так он 2квт не выдает. Если писать по заявленным характеристикам производителя, так тут страницы не хватит, чтобы все уси перечислить:mocking:
Это клон ХХХ6500. Просто таблички разные.
Вот смотри. Это Ланзар
http://ampguts.realmofexcursion.com/Lanzar_OPTI_4000D/inside1.jpg
А это Саундстрим ХХХ
http://ampguts.realmofexcursion.com/Soundstream_XXX6500/inside5.jpg
RASKA - 2013,14
AMT спл шоу - 2014
