Nastradamus Опубликовано 5 ноября, 2009 Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 Устройство усилителя SounDigital 12kD A- Power transformers: they are connected to the battery positive +12V (or any voltage in the 8-18V range) and to the Power supply FETs, which will open and close (controlled by the microprocessor) and generate an AC voltage on their outputs. B- Power Supply FETs: explained on A. Each one is rated at 202A continuous, but they can handle up to 4x this number by working pulsed. Working in PWM mode, the time they stay opened changes all the time in order to control the power supply voltage and not damage the output stage. This is why our amplifiers work from 8V to 18V or even more. C- Power diodes: Just as in a alternator, they rectify the alternating voltage into DC voltage. D- Capacitor bank: Provide the capacitance needed to eliminate the pulsating ripple. After the Capacitors the voltage on the SD12kD can be up to 250Vdc. E- Output FETs: 16 units working in H-bridge mode (means that all voltage RMS from power supply is provided to the load). Being a D class amplifier they work in PWM mode to build a sine shaped signal. F- Current detection: shunt resistors measure the current from the power supply and send the information to the brain of the amplifier, the 20MHz microprocessor. If a short-circuit occur on the output, the microprocessor shut down the power supply, as an example. G- Output filter: Being a low-pass filter, it will clean the high-frequency modulating signal from the output stage, allowing only the audio-range signal to pass. H- Microprocessor and drivers, together they control all the switching devices (FETs) and monitor the protections. п.с. переводить не стал специально, чтобы где нибудь не ошибиться. даже без знания энглиша, можно получить представление, что для чего нужно и как все работает. Титанат от БасКлуба Упакуйся по полной - ЗАКАЗАТЬ Ссылка на комментарий
pox73 Опубликовано 5 ноября, 2009 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 Прям техногенная порнуха Ссылка на комментарий
SergeyS Опубликовано 5 ноября, 2009 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 (изменено) а как ему работать, трансформатор голимый) Выглядит как УПС на компе , 220 в 12 вольт , а этот усь 12 вольт переделал в 220 вольт. Изменено 5 ноября, 2009 пользователем SergeyS Team Ural SQ Ссылка на комментарий
Nastradamus Опубликовано 5 ноября, 2009 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 а что ты ожидал увидеть внутри усилителя Д-класса ? с такой логикой можно и саб назвать насосом, только насос воду качает, а саб воздух ... Титанат от БасКлуба Упакуйся по полной - ЗАКАЗАТЬ Ссылка на комментарий
pox73 Опубликовано 5 ноября, 2009 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 а что ты ожидал увидеть внутри усилителя Д-класса ? с такой логикой можно и саб назвать насосом, только насос воду качает, а саб воздух ... Скорее уж не насосом а утюгом :) Ссылка на комментарий
SergeyS Опубликовано 5 ноября, 2009 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 Не ты не понял, вообще о чём я говорил. Я большего и не ожидал, ясен пень что этот усь может тупо синус воспроизводить. Team Ural SQ Ссылка на комментарий
deepreykztz Опубликовано 5 ноября, 2009 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 Да ........трансы серьезные Ссылка на комментарий
Гость zerg Опубликовано 5 ноября, 2009 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 Не ты не понял, вообще о чём я говорил. Я большего и не ожидал, ясен пень что этот усь может тупо синус воспроизводить. зато как:greeting: Ссылка на комментарий
SergeyS Опубликовано 5 ноября, 2009 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 Ну я думаю))))0 Не слабо точно. Team Ural SQ Ссылка на комментарий
Гость zerg Опубликовано 5 ноября, 2009 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 точно не помню про какой усил было, но типа всё что выше 80 херцев отрезало на входе Ссылка на комментарий
Airat Опубликовано 5 ноября, 2009 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 Ого вот и дилеры SD в России назревают... ;) Ссылка на комментарий
Ded Vitos Опубликовано 5 ноября, 2009 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 КРУТО !!!!!!!!! чтож в 16kD ???:boredom: Ссылка на комментарий
Jtag Опубликовано 5 ноября, 2009 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 Ну так как же это работает? на низкоомку, кпд уся, как с просадками борется, итд? Ссылка на комментарий
Nastradamus Опубликовано 5 ноября, 2009 Автор Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 когда есть усилители, которые в состоянии на 1 ом выдать 12к на 12,6 вольт, зачем себе на одно место искать приключений с низкоомной нагрузкой. мало 12к? подними напругу до 16 вольт и будешь иметь вот столько .... http://www.youtube.com/watch?v=KzQR_7dVeg8 п.с. в 0,5 на замер работают, но как любой производитель скажет - этот режим на свой страх и риск. Титанат от БасКлуба Упакуйся по полной - ЗАКАЗАТЬ Ссылка на комментарий
Bass Warrior Опубликовано 5 ноября, 2009 Ссылка на пост Ссылка на тему Поделиться Опубликовано 5 ноября, 2009 (изменено) говори уже цену все красиво, если придераться - то слишком далеко драйвера находятся от транзов блокапитания, чтоможет породить некоторую нестабильность при высокой частоте генерации ТЕОРЕТИЧЕСКИ имхо, но наверное разработчики все предусмотрели:flag_of_truce: Изменено 5 ноября, 2009 пользователем biohaz Ссылка на комментарий
